Swimming pools in my zed
- Chris_D
Oh dear, oh dear, there seems to be water ingress occurring somewhere. Sigh.
Was giving Bruiser a thorough clean today in preparation for the hardtop coming off and on vacuuming the carpets noticed corrosion on the driver side seat rails at the back. Not good, I thought to myself, and on further inspection, lifting up the carpets both sides behind the seats the floorpan is absolutely sodden. I don't know how long it's been there as I havent been using it for a few months. Would assume from the jetwash today but that corrosion on the seatrails suggests otherwise.
Looks like a seats out, doorcards off jobby. Anyone else experienced similar?
Have wedged in some small towels to soak up the water but the sponge under the carpet has done an admirable job of retaining moisture
Crapsticks!
Crapsticks!
Chris, have you checked your door cards as it seems the place where water can enter. Check to see if the plastic film is in place behind the card.
And I didn't to the pee this time, eh
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Chris_D
Yer. Doorcards coming off next weekend to check membranes. Just hope i dont have holes in the floorpanfirebobby wrote:Chris, have you checked your door cards as it seems the place where water can enter. Check to see if the plastic film is in place behind the card.
- Silverzedtom
I'd stick a de humidifier in there until you can get it sorted. Hope it's an easy fix.
E85 2.5si
F55 Cooper S
F55 Cooper S
You shouldn't have unless someone has removed a bung, may be worth getting the car up in the air and having a look, if the door card plastics are OK.Chris_D wrote:Yer. Doorcards coming off next weekend to check membranes. Just hope i dont have holes in the floorpanfirebobby wrote:Chris, have you checked your door cards as it seems the place where water can enter. Check to see if the plastic film is in place behind the card.
Just checked mine and it's nice and dry
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Chris_D
You lucky feller!firebobby wrote:You shouldn't have unless someone has removed a bung, may be worth getting the car up in the air and having a look, if the door card plastics are OK.Chris_D wrote:Yer. Doorcards coming off next weekend to check membranes. Just hope i dont have holes in the floorpanfirebobby wrote:Chris, have you checked your door cards as it seems the place where water can enter. Check to see if the plastic film is in place behind the card.
I think the lack of an undertray may be a contributary factor.
Further exploration required....
Now i really think we ought to resume normal mickey-taking service....
- buzyg
Can't disagree with that. Here's what you need to sort it .Chris_D wrote:You lucky feller!firebobby wrote:You shouldn't have unless someone has removed a bung, may be worth getting the car up in the air and having a look, if the door card plastics are OK.Chris_D wrote: Yer. Doorcards coming off next weekend to check membranes. Just hope i dont have holes in the floorpan
- Jollyjoiner
Been there, done that.
Still had no idea where the water came from but I'm with some others on hear in thinking that I don't believe water can get in from behind the door cards. I think water can get past the door seals around the mirror area by the seals being to old and dry, then the water runs down the seal and comes in over the sill at the bottom front corner of the door.
2009 35i DCT silver
SLT mapped to 365bhp
- Chris_D
ThxSilverzedtom wrote:I'd stick a de humidifier in there until you can get it sorted. Hope it's an easy fix.
- Chris_D
Thx ray doorcards off next weekend....raymond.harper wrote:viewtopic.php?t=71222
- Chris_D
Aye. Warrants further poking around i think....Jollyjoiner wrote:Been there, done that.
- Chris_D
Can i borrow your Babyliss Pro with perm attachment then buzy lar?buzyg wrote:Can't disagree with that. Here's what you need to sort it .Chris_D wrote:You lucky feller!firebobby wrote:
- buzyg
Any time our kidChris_D wrote:Can i borrow your Babyliss Pro with perm attachment then buzy lar?buzyg wrote:Can't disagree with that. Here's what you need to sort it .Chris_D wrote: You lucky feller!
Dont discount roof drain blockage. Water fills up and then overflows behind seat under carpet.
