Intravee and parking sensors
I have 4 parking sensors at the back of the car but the intravee only shows the inboard two on the sat nav screen. Is this normal or should all 4 show distance?
2003 Launch car : 3.0 litre E85 in Sterling grey
- Bing
Should show all 4 - perhaps the two outboard ones are not working, or disconnected ?
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
Cheers Bing. They have just started playing up and I thought the left one wasn't clicking. The right one seems very weak too and Carly says there is a fault in the right one. Does anyone know if they are linked? If the right one was shot would it stop the left from working?
Also - where is the best place to get a body coloured replacement sensor? Ebay at £25? If I need two that's £50.!! Oh for a black car
- srhutch
- Moderator
Solid BlackAny1else wrote: ↑Sat Apr 01, 2017 6:31 pm Cheers Bing. They have just started playing up and I thought the left one wasn't clicking. The right one seems very weak too and Carly says there is a fault in the right one. Does anyone know if they are linked? If the right one was shot would it stop the left from working?
Black Sapphire
Carbon Black
Ruby Black
Need to be more specific
Specifically - Sterling grey blacksrhutch wrote: ↑Sat Apr 01, 2017 6:42 pmSolid BlackAny1else wrote: ↑Sat Apr 01, 2017 6:31 pm Cheers Bing. They have just started playing up and I thought the left one wasn't clicking. The right one seems very weak too and Carly says there is a fault in the right one. Does anyone know if they are linked? If the right one was shot would it stop the left from working?
Black Sapphire
Carbon Black
Ruby Black
- 85genius
Any1else wrote: ↑Sat Apr 01, 2017 6:48 pmSpecifically - Sterling grey blacksrhutch wrote: ↑Sat Apr 01, 2017 6:42 pmSolid BlackAny1else wrote: ↑Sat Apr 01, 2017 6:31 pm Cheers Bing. They have just started playing up and I thought the left one wasn't clicking. The right one seems very weak too and Carly says there is a fault in the right one. Does anyone know if they are linked? If the right one was shot would it stop the left from working?
Black Sapphire
Carbon Black
Ruby Black
Audi quattro driver
NOW SOLD - Ruby Black 3.0 SI Roadster
Previous - E85 2.5 Ti Silver - See avatar photo - R.I.P Destroyed by a Tranny
Since it is the two outboard sensors that are playing up I wonder if it is the control unit. Can anyone point me to where it is located so I can check connections?
- srhutch
- Moderator
To test that swap two of the sensors over. If the problem moves it the sensors. (more than likely it will be)
Great idea. Will give that a go.
- bladeowner
If you put the car in reverse and then lightly touch the sensor you can feel a slight vibration if it's working to some extent. You can compare with the ones you know are working. The control unit is behind carpet in the RHS side of the boot. I had an issue with a sensor that seemed to be vibrating when touched but was occasionally giving problems. I reconnected the connectors to the control unit a few times and it's been fine ever since.
2004 Sapphire Black 2.5 SE Z4 SMG
Excellent - thanks. Will check that before taking the bumper off. The middle two certainly have a strong pulse to them but the outer ones are pretty weak or non-existant.bladeowner wrote: ↑Sun Apr 02, 2017 11:30 pmIf you put the car in reverse and then lightly touch the sensor you can feel a slight vibration if it's working to some extent. You can compare with the ones you know are working. The control unit is behind carpet in the RHS side of the boot. I had an issue with a sensor that seemed to be vibrating when touched but was occasionally giving problems. I reconnected the connectors to the control unit a few times and it's been fine ever since.
Stuck the pc on it tonight (cos its pissing down) and I see a few errors in the PDC module. After translation I have :-
1. a "Swing out error" in the "right rear converter"
2. a "Short circuit against U-batt" and "short circuit against ground" on the "rear speakers" and the "front sound generator"
I get the feeling that the rear right sensor is shot and the car is therefore short circuiting through that sensor.
Will check the control unit when it stops raining though. Might be something simple.
Checked the connections to the control unit and they were fine. Swapped a good sensor for a dud one and the sensor worked so the control unit is fine. Need to order a couple of sensors now.
Called BMW and guess what they wanted for one - £166 inc VAT.
OK, onto ebay for sensors and paint.
- markplant
Try here
http://www.ebay.co.uk/usr/pdcexperts
Cheers - will have a look.
Ordered two new ones and installed them tonight. Now when I engage reverse I get no beep from the car and the Intravee screen doesn't come up. When it's in reverse all the sensors pulse so I know they are working. Is there anything else I need to reset? Cleared an error with Carly but it still doesn't beep and register objects behind the car.
