Hall sensor
- Sgr74
- Ducklakeview
Hall sensor
There are several on the E85 roof, which one??
Mike
Mike
- Sgr74
Hall sensor
Don't know. The roof won't go all the way down first time. You have to put it up a bit, then down. Then up a bit, then down. Until it sits right. Have you encountered this before?
Black 2.5 Roadie.
- Ducklakeview
Hall sensor
Yes, there are sensors on the hinges. Have you relocated your roof motor by any chance?
Mike
Mike
- Sgr74
Hall sensor
Yes. I bought the car with the roof not working.Ducklakeview wrote: ↑Thu Apr 20, 2017 10:54 pm Yes, there are sensors on the hinges. Have you relocated your roof motor by any chance?
Mike
Black 2.5 Roadie.
Hall sensor
i think mine might have this issue now as tonight i thought i would go for a blast, windows go down , light on switch flashes and roof goes down, but only so far ( anything from 1 inch before the bottom or several inches) then it all seems to stop. if you then try to raise the roof nothing happens, if help the roof a bit it will raise all the way and lock off ( well the light goes off on the switch. this happens if you do it off the key, the central switch or the gaptech.
HELP
HELP
Sterling Grey 3.0i E85 Black Heated Leather M sports seats , 224's ,Sat Nav, Bluetooth, Xenons, PDC, Gaptech ,Cruise and a nice warm garage. NOW GONE
Silver 3.0i Z4 NOW GONE
- Sgr74
Hall sensor
Mine goes up fine. Needs a push to start the opening process. Stops between 20-35mm when opening. It's really pissing me off. May visit BMW to see if they have any input. Or maybe a hydrolic specialist.Zoomer wrote: ↑Fri May 05, 2017 9:33 pm i think mine might have this issue now as tonight i thought i would go for a blast, windows go down , light on switch flashes and roof goes down, but only so far ( anything from 1 inch before the bottom or several inches) then it all seems to stop. if you then try to raise the roof nothing happens, if help the roof a bit it will raise all the way and lock off ( well the light goes off on the switch. this happens if you do it off the key, the central switch or the gaptech.
HELP
Black 2.5 Roadie.
Hall sensor
Mike I have done the obvious and removed the microswitch and wedged it so that its s made. The roof does lowers until the last inch or so then stops. It not raise without helping it to start but if you do help it t fully raises and locks. Where are the hall sensors that you mentioned. ( motor is relocated , sadly before you started doing them)
