Sat nav gps problem
- jabber
Sat nav gps problem
My sat nav keeps losing gps lock,I had fitted a second hand replacement gps unit and it is still the same am I correct in thinking the dvd sat nav drive is the next likely culprit?
Z less again
- srhutch
- Moderator
Sat nav gps problem
Have you checked how many satellites are being seen in the hidden menu.
Also, get a new gps antenna. Under a tenner for one off eBay.
- jabber
Sat nav gps problem
I have tried a new antenna from ebay but it would only work 100% if it was mounted on top of the dash board if I left it in its correct position above the interior light it only locked intermittently, which leads me to believe there is a problem elsewhere
Z less again
Sat nav gps problem
I bought one from eBay and mounted it by the magnet on the inner rear wing and it works there no problem. If it works 100% mounted on the dash then surely that must be the problem
- jabber
Sat nav gps problem
Where in the rear wing have you positioned it?jamesditchy wrote: ↑Tue Apr 25, 2017 8:48 pm I bought one from eBay and mounted it by the magnet on the inner rear wing and it works there no problem. If it works 100% mounted on the dash then surely that must be the problem
Z less again
- mac27040
Sat nav gps problem
check the cable to the antenna as i had a similar problem, the wire is very thin and i had a break within the wire, luckily it was close to the joint so bent the cable and struck it in position, problem solved.
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
