Hi all
I'm just in the process of relocating my roof motor. I've hit a problem where I cant get the short hydraulic pipe to allow me to get the motor into the boot because it's the wrong side of a bar, the opposite end to the pump and motor. Can anyone suggest how I manage to get the pipe the other side to give me enough length to get the motor in the boot.
Thanks Guy
Roof issue
Roof issue
May sound silly but unbolt the pipe from the pump and re route it as required then bolt it back on . Top up the fluid. The pump is self bleeding so it should be fine .
Roof issue
Yeah was gonna do that but I was told they usually leak once they've been undone and I don't have any spare seals. Probably end up giving it a go though. Cheers.
Roof issue
Unlikely to be honest, just make sure you get all the cooper washers back on and you should be fine .
