Yellow handbrake and yellow traction control light
Wendy02
Post by Wendy02 » Mon May 22, 2017 8:01 pm
I have a 2.0i and have the yellow brake light and traction control light come up sometimes but disappears when the engine is restarted. The lights are not permanent. I've had the dsc unit recoded and the lights don't come back for weeks. Any idea what else this could be? The repair option is £850 and a new unit is over £1800.
The 2.0i litre doesn't have dsc sensors on the master cylinder.
wingnut
Post by wingnut » Mon May 22, 2017 8:39 pm
Hi
Had brake light and traction light on mine (2.0) a few weeks back, which turned out to be the brake pressure sensors on the master cylinder. Its just a case of tracing which one has failed, I replaced both as I understand its a common fault. Cheap fix.
Good luck
Chris_D
Post by Chris_D » Mon May 22, 2017 9:24 pm
tried scanning for fault codes?
abar121
Post by abar121 » Mon May 22, 2017 9:44 pm
Just having this on my M model. With a stock Z4 you should be able to get some decent error codes from INPA etc.
I'm stuck with my M and it's different ECU / modules damm it.
'07 Z4M Interlagos Blue. All options except extended leather.
Z43.0Si
Post by Z43.0Si » Mon May 22, 2017 10:05 pm
The ABS pump is prone to failure on our Zeds. You can get it rebuilt for around £250 plus labour costs.
Wendy02
Post by Wendy02 » Tue May 23, 2017 6:43 am
Hi thanks for the replies. I've had it connected to the BMW diagnostic computer Saturday. Came up with dsc coding. Had it recoded and still getting both lights. The 2.0i doesn't have the brake pressure sensors on the side of the master cylinder. Just the 2 pipes going into the dsc unit. I've took photos to confirm this. Maybe I'm missing something. I'm taking it back into BMW tonight for free if they can do anything to it.
greg1953
Post by greg1953 » Tue May 23, 2017 7:15 am
Wendy02 wrote: Tue May 23, 2017 6:43 am Hi thanks for the replies. I've had it connected to the BMW diagnostic computer Saturday. Came up with dsc coding. Had it recoded and still getting both lights. The 2.0i doesn't have the brake pressure sensors on the side of the master cylinder. Just the 2 pipes going into the dsc unit. I've took photos to confirm this. Maybe I'm missing something. I'm taking it back into BMW tonight for free if they can do anything to it.
If you need the get the ABS unit refurbed read my post about BBA - Reman. I had to buy a new unit from BMW at a price of £2090.
Theres a firm in Derbyshire http://www.ecutesting.com/ecu_testing__ ... epair.html they have a good reputation.
Wendy02
Post by Wendy02 » Tue May 23, 2017 7:01 pm
Been to BMW today, had the steering wheel angle sensor calibrated. Hopefully that will have sorted out the 2 lights. No fault codes for the dsc unit or sensors.
