Thermostat activation
Chris1981
Post by Chris1981 » Sun May 28, 2017 8:22 am
Had a MAP thermostat activation error code appear a few times now, 3.0 si N52 engine.
No over heating or running cold, temp gauge sits exactly in the middle as it should and car runs great!
Anyone else experienced this issue, is it just the thermostat or an early sign my pump is failing??
Already bought a thermostat but wanted your thoughts before I go ahead and change it as would rather do pump at same time if required!
C
E86 Coupe 3.0si Sport - Montego Blue, Pearl Grey with Piano Black dash
BC BR series Coilovers, powerflex bushes, 15mm spacers, Custom SS exhaust, CDV delete
biojo
Post by biojo » Sun May 28, 2017 10:18 am
if you can read the coolant temp, you should be able to see if the thermostat is activating, I know on intravee car shows 97-99 normally, put it in 6th as say 30 and accelerator all way down, this should tell thermostat to open and temp should drop a few degrees withing a few seconds
Chris1981
Post by Chris1981 » Sun May 28, 2017 12:42 pm
Thanks for the info, don't have intravee... what is it exactly? Do have Carly but typically the parameter section doesn't work so can't check what's going on in the engine, in talks with tech support but it's like pulling teeth! :headbang:
biojo
Post by biojo » Sun May 28, 2017 1:10 pm
intravee is ipod thing, but on sat nav can display live temps / speed etc.
Chris1981
Post by Chris1981 » Sun May 28, 2017 4:47 pm
Ah, no sat nav so not an option really... will just have to swap and hope that stops the code from reappearing!
Scooba_Steve
Post by Scooba_Steve » Tue May 30, 2017 10:15 am
Got laptop? Get cable and INPA, or if you're near NW London come see me.
Chris1981
Post by Chris1981 » Tue May 30, 2017 10:21 am
Thanks Scooba Steve will look into INPA... I'm midlands based unfortunately but thanks for the offer! :thumbsup:
