I'm reading two ABS errors, 5E00 and 5E01. These are test and test time-out faults. I tested the pump and valves using INPA. The pump definitely works, and I did hear the inlet valves click. The two pressure switches also appear to be reading normally. Dash symptoms are the ABS light ( always on) and flashing DSC light when the brake pedal is pressed with some force.
Any ideas as to my issue?
2003 3.0i E85 abs errors
- mac27040
internet says this is the error fault
5E00 Tyre Test Active
5E01 Tyre Test Timeout
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
Yes, I found those code titles as well. What can actually cause those faults?
I have exactly the same symptoms. Did anyone reply to this post ?
Sorted. It's not a tyre test, it's an end of line test. The abs needs to learn the steering to roll angle.
A suitable size roundabout did the trick.
Press the brake until the DSC light flashes, drive into the roundabout in a straight line, drive briskly around the roundabout and leave at the exit you started from and the abs light will go out.
