Zed won't start :( Help!
- GedS
So drove my car to work this morning (startup was a bit poor, didn't spark on first couple of key turns, then started), when I came back to the car in the afternoon, it wouldnt start at all.
- Battery: All electrics are fine, windows, seat heaters, air con, lights etc, wipers run fine (haven't tested the voltage yet but will in the morning)
-Tried to jump & bump start, but nothing, just the gears catching, but no engine turnover at all
-Key "appears" to function ok. Unlocks the car, 1st 2 positions seem fine, and I did a method 2 sync which seemed to work, but wouldn't help the non start issue.
-I can hear the relay to the starter clicking
-I can hear the fuel pump (or at least what I think is the fuel pump when I turn the key
I'm now out of ideas, except for tw@tting the starter motor
Can any of you guys help and save me a packet?
Thanks in advance folks
3.0si 19" CSL's, CDV delete, K&N Air Filter, Powerflex Bushes
Work in Progress
- sw4nny
Where are you based maybe someone could help with a code reader,I am know mechanic but my best guess would be coilsGedS wrote: ↑Wed May 31, 2017 8:40 pm So drove my car to work this morning (startup was a bit poor, didn't spark on first couple of key turns, then started), when I came back to the car in the afternoon, it wouldnt start at all.
- GedS
Im based in stockport.
Ive just been reading up on ignition switch faults. Might try that. Would seem to fit the fault.... Its only position 3 that doesnt respond, so maybe??????
Work in Progress
- fixit man
Sounds like it could be the starter motor too... if the starter relay is clicking ignition switch would be ok but not the starter , best to get a volt meter and start measuring
- GedS
But would it not start when bump started if it was the starter?
Work in Progress
Yup
///M|Silver Grey|Black Leather|BT|Nav|DSP|Heated Seats|PDC|Stubby|Turner Limiters|Turner Rear Top Mounts|Bilstein B12|Powerflex ARB Bushes|Powerflex Lollipops|M-Track|
SOLD
SOLD
- GedS
Therefore, not a starter motor??
I am mechanically retarded by the way .
Work in Progress
- fixit man
- GedS
still no joy with this situation My lovely zed is stranded. Looks like the only option is an indy and potentially getting ripped off.
Work in Progress
For £15 or so try swapping out the ign switch?
GedS, I had exactly the same issue yesterday. All the vital signs were there. Doors unlocked all ignition lights on, relay clicking but no fire.
Put the volt meter across the battery and there were 9.74v where there should have been around 12.4v. Out came the jump leads and away we go first turn of the key. Quick check on voltage with engine running and we have 14.3v. So all seems to be charging. Decided to go for a run for 20 minutes, calling in at my local indie on the way. They kindly put the battery tester on it for me and the battery was only at 20%. finished my run and after tea went to start the Z, again. No joy again.
This morning first thing picked up replacement battery and fitted. 12.7v standing and 14.7v with engine running. All running again. I would suggest you call in to your local guy and get a battery check done first.
CookieP
Just seen a typo on my last post where I said battery was at 20% when it was actually 60%.
CookieP
It should unless you make the same mistake as my mate...we tried 3 times to bump start his car...it was only after the third time he realised he'd not turned the ignition on....he was really popular I can tell you...
- fixit man
Yes, exactly what I was thinking ....there's a lot to get rightTruman wrote: ↑Fri Jun 02, 2017 8:22 pmIt should unless you make the same mistake as my mate...we tried 3 times to bump start his car...it was only after the third time he realised he'd not turned the ignition on....he was really popular I can tell you...
- Ethicsgradient
Not unheard of for a starter motor to suddenly crap itself .. Mine did .. Stopped for fuel on the M6 toll road on way home from sweatyland .. Thought uh oh when I felt it behave sluggish and sound a bit off, but it managed to start it . Got home ..went to bed .. got up in the morning ..bet myself a tenner she wouldn't start , I won my bet .
