Hi all,
I have a 2003 3.0 Z4 and it's an excellent car, however it's getting on a bit now and starting to use a fair bit of oil and unfortunately the oil level warning light doesn't no longer works.
The yellow engine management warning light came on suddenly the other day, along with a major loss of power and rough running. It sounded like a cylinder wasn't firing so I checked the plugs and coil but they were all fine. By this time I'd driven 20 miles to get home.
I remembered having a similar problem when the oil level was very low so I checked the oil and it was 'off the stick'. I filled up the oil hoping for the warning light to go out (like last time) but the light's still on and the engine's still running really rough.
I've just ordered a diagnostic cable to check for error messages and am hoping I can somehow re-set the EMS and all will be back to normal. Is this likely or am I just kidding myself? Have I done serious damage? Should I make an advance garage booking to I can get her back on the road pronto?
Very grateful for any advice or suggestions as I wait nervously for the cable to arrive.
David
Engine Management Warning Light Problem
- vester86
first scan for errors, then report back here.
nobody knows at this moment, but an educated guess from me is that low oil level does not give a rough running engine... would suspect bobbins first
- Chris_D
I'd suggest replacing your ccv system to cancel that out. I'm almost certain this could be ur problem. They become mechanically compromised over time, especially atthat age. Mines an 03 3.0 and it was one of the first things i did to address high oil consumption.
Worked a treat - hasnt needed a drop of oil in 5000 miles since the swap wheras i was topping up every 1000 miles with about 1-2L.
Could also be a raft of other causes but i'd suggest ccv renew as it will be hard/brittle and the diaphragm inside the separator can fail too at this age giving rise to very rough idle and powerdrop. My diaphragm went due to an associated problem with the throttlebody. Thus, you could be solving both problems in one fell swoop potentially.
Go for the febi cold climate version if so- it's got better insulation, protecting against condensate buildup inside the system. Pita to fit but worth it.
Good luck fella
Edit: plus ofc as per vesters suggestion to obd scan. (I use carly) but theres many options available.
Good luck fella
Hi,
I've downloaded the errors and tried to attach the files but I keep getting an error that the file extension is invalid!!
So I've pasted the details below. Sorry it's so long
There are quite a few lines but I'm not sure which are relevant. Any ideas?
Thanks,
David
E R R O R M E M O R Y R E P O R T
Date: 06/13/17 19:09:22
ECU: D_STVR2
JobStatus: ---
- API-Job FsLesen: job status error
Variant: CVM_IV >>>>>>>>>> No error found <<<<<<<<<<<
Variant: LSZ_2 >>>>>>>>>> No error found <<<<<<<<<<<
Ecu : D_0066 IFH-0009: NO RESPONSE FROM CONTROLUNIT
Variant: RLS_DS2 >>>>>>>>>> No error found <<<<<<<<<<<
Ecu : D_0060 IFH-0009: NO RESPONSE FROM CONTROLUNIT
Variant: EWS3 1 Error in error memory
Error registration 1 : 0x000F: power on reset <<<<!!!
Error accurances: 31
Static error
Error code: 0F FF
Ecu : D_0057 IFH-0009: NO RESPONSE FROM CONTROLUNIT
Variant: ZKE5 2 Error in error memory
Error registration 1 : 0x0027: Central locking system Relay Locking Driver's door: Contact for opening has open circuit or Contact for closing is sticking <<<<!!!
Static error
Error code: 27 3F
Error registration 2 : 0x003D: Central locking system: Short circuit or Open circuit at Motor Tailgate <<<<!!!
Error accurances: 17
Sporadic error
Error code: 3D 11
Variant: SZM46 >>>>>>>>>> No error found <<<<<<<<<<<
Variant: KOMBI85 4 Error in error memory
Error registration 1 : 0x0020: Airbag <<<<!!!
Error accurances: 255
Error present
K-Bus telegram 70h failed (Mask 10)
Error code: 20 60 FF
Error registration 2 : 0x00FA: no CAN ID EPS1 <<<<!!!
Error accurances: 0
Open circuit
Sporadic error
Error code: FA 84 00
Error registration 3 : 0x0011: Oil level sensor defective <<<<!!!
Error accurances: 5
Open circuit
Sporadic error
Error code: 11 84 05
Error registration 4 : 0x0000: Unknown error location <<<<!!!
Error accurances: 0
Error code: 00 00 00
Ecu : D_005B IFH-0009: NO RESPONSE FROM CONTROLUNIT
Variant: RADIO >>>>>>>>>> No error found <<<<<<<<<<<
Ecu : D_006A IFH-0009: NO RESPONSE FROM CONTROLUNIT
Ecu : D_00C8 IFH-0009: NO RESPONSE FROM CONTROLUNIT
Ecu : D_00F0 SYS-0012: IDENTIFICATION ERROR
Ecu : D_00ED IFH-0009: NO RESPONSE FROM CONTROLUNIT
Ecu : D_003B SYS-0012: IDENTIFICATION ERROR
Ecu : D_0048 IFH-0009: NO RESPONSE FROM CONTROLUNIT
Ecu : D_007F SYS-0012: IDENTIFICATION ERROR
Ecu : D_00BB SYS-0012: IDENTIFICATION ERROR
Variant: SM46_4 >>>>>>>>>> No error found <<<<<<<<<<<
Ecu : D_00DA SYS-0012: IDENTIFICATION ERROR
This content will stored temporary temporär in ..\inpa\sgdat\na_fs.tmp
Variant: SIM85 1 Error in information memory
Info registration 1 : 0x9485: Clamp R Signal inconsistent <<<<!!!
Error accurances:
Error code: 94 85 20
Variant: SBSL85 1 Error in information memory
Info registration 1 : 0x989F: Power-On-Reset uP <<<<!!!
Error accurances:
Error code: 98 9F 20
Variant: SBSR85 1 Error in information memory
Info registration 1 : 0x991F: Power-On-Reset uP <<<<!!!
Error accurances:
Error code: 99 1F 20
Ecu : D_STVL2 IFH-0009: NO RESPONSE FROM CONTROLUNIT
Ecu : D_STVR2 IFH-0009: NO RESPONSE FROM CONTROLUNIT
Variant: CVM_IV 3 Error in information memory
Info registration 1 : 0x0070: undervoltage at KL30 <<<<!!!
Static error
Error code: 70 3F
Info registration 2 : 0x0079: no status information from instrument panel <<<<!!!
Error accurances: 2
Sporadic error
Error code: 79 02
Info registration 3 : 0x0072: undervoltage on supply of hall sensors <<<<!!!
Error accurances: 1
Sporadic error
Error code: 72 01
Variant: ZKE5 5 Error in information memory
Info registration 1 : 0x0090: Battery Voltage: Open circuit <<<<!!!
Error accurances: 16
Static error
Error code: 90 30
Info registration 2 : 0x0085: Alarm memory: Tailgate <<<<!!!
Error accurances: 4
Sporadic error
Error code: 85 04
Info registration 3 : 0x0081: Alarm memory: Door contact Driver's door <<<<!!!
Error accurances: 6
Sporadic error
Error code: 81 06
Info registration 4 : 0x008A: Alarm memory: Radio interior protection <<<<!!!
Static error
Error code: 8A 3F
Info registration 5 : 0x0088: Alarm memory: Hood <<<<!!!
Static error
Error code: 88 3F
This content will stored temporary temporär in ..\inpa\sgdat\na_is.tmp
Thanks,
David
ECU: D_STVR2
JobStatus: ---
Static error
Error code: 0F FF
Static error
Error code: 27 3F
Sporadic error
Error code: 3D 11
Error present
Error accurances: 0
Open circuit
Sporadic error
Error accurances: 5
Open circuit
Sporadic error
Error accurances: 0
Error accurances:
Error accurances:
Error accurances:
Static error
Error code: 70 3F
Error accurances: 2
Sporadic error
Error code: 79 02
Error accurances: 1
Sporadic error
Error code: 72 01
Static error
Error code: 90 30
Error accurances: 4
Sporadic error
Error code: 85 04
Error accurances: 6
Sporadic error
Error code: 81 06
Static error
Error code: 8A 3F
Static error
Error code: 88 3F
- vester86
wauw, thats a lot of error codes, especially from the airbag.
i don't see any errors that really relate to the problem you were discribing, looks like your car has had some battery issues in the past.
worth to fix the oil level sensor, that one had some nasty consequences in my car (made short circuit & blocked some other data somehow)
can you try to clear all codes & see which one returns after a decent drive?
- Roundozo
Randomly I might have an oil level sensor in my shed for your car. If you find the part number I can check and if it fits you can have it. It is used but I believe it's functional (it's not from my car but was given to me in a bundle of Z4 stuff from another forum member)
Past - Z4 Coupe, gone but not forgotten
Present - 530d M sport touring
An update....
So I cleared the error messages and took her for a short drive. Still very juddery as if missing on one or two cylinders (just a guess) and very low on power.
No error messages any more. No EML illuminated.
The 'Engine' telltale light is lit, which the manual says means 'Exhaust emissions have deteriorated'. I also noticed a smell a bit like like burning rubber.
Doesn't sound too good when I write it down like that
Any ideas?
Any ideas?
- vester86
very strange, when running that bad you should have an error or 2. no clue on where you should look, especially with the "burnt rubber" smell
A quick update....
I took the Z4 in to a local garage and apparently they hooked her up to their computer and straight away got a 'misfire cylinder 5' error. They swopped in the new coil pack I fortunately left with them and that fixed the problem. Now I'm a bit frustrated because (a) when I swopped the same coil pack in previously it didn't fix the problem and (b) when I connected up my laptop I got no error message Still, at least all is now well with the world
I'm wondering which software they would have used. I believe they used it while the engine was running while I used INPA which didn't show the error. Would be good to know for the future. Any thoughts?
Thanks for the support,
David
David
