Poly bushes
- Sgr74
Poly bushes
Just fitted rear trailing arm poly bushes before having the geometry done. Now the back end squeaks like a randy mouse. Should I give it time to bed in or bite the bullet and fit oem?
Black 2.5 Roadie.
Poly bushes
Fitted Powerflex poly RTAB to mine and not a squeak.............
2004 E85 Z4 2.5i SE Sterling Grey.
- GuidoK
Poly bushes
What brand did you fit?
Did you use enough copper lube?
Have fitted mine for years now (powerflex)(4 years ago or so), no squeaks.
