Properly been covers but a couple of questions
First one being when the car is locked from the key then reopened sometimes the drivers door will not unlock anyone have a fix for this ?
Second one is when you shut both doors they don't have make a crap noise any one solved this ?
Oh one other one when I put the roof down via the key the windows go back up is there away of keeping the windows down ?
Lazy drivers door lock
OnlineMr Tidy
Sorry I can't help with the lock question, but assuming your car is a pre-facelift I think the crap noise when you close the doors is because they don't have sound deadening on them but the facelift did.
Ah - can't help with roof down questions - mine is a Coupe!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Anyone else on the lazy drivers door lock ?
- kis
Had this problem on another Zed. In the end if failed all together. Would never open with the key, but would always lock with key. I replaced the door actuator mechanism and this didn't solve anything. Trust me that was a pain in itself! Such a small working space!
Apparently the next step is the central locking module? There are two relays that you need to replace and fingers crossed this solves the problem. This was a while ago but give it a google should find a thread or two on the topic.
Relatively straight forward if you know your way around a car and soldering iron. Otherwise you could always pop the module and give it to a mate?
If that doesn't help... not sure bud! Good luck!
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Thanks kis just realised you replied
It works sometimes then sometimes not its got to be a relay
- Ewazix
Sounds like it could be the classic GM5 module (search should throw lots up). The modules are coded to your car so buying 2nd hand may be a false economy as it will need coding and you have no way of knowing the replacement wont go duff as problems seem to be intermittent.
A lot of people use repair services like this guy on ebay who has good feedback (I've kept the link for the inevitable day mine might go ) http://www.ebay.co.uk/itm/REPAIR-SERVIC ... 1438.l2649
These are the module relays if you are really handy with soldering http://www.ebay.co.uk/itm/2-Pcs-BMW-GM5 ... 1438.l2649
There are loads of vids on how to remove the module which is pretty easy and located behind the glovebox
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
- kis
No worries bud! Hope it's an easy fix (now you know it's prob the module!)
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
