Bulb Warning Light!
Bulb Warning Light!
Hello, I've got the bulb warning light on my dashboard lit up...but all my bulbs are working fine - any ideas why this is showing?
Also, is this something I would be able to reset if I had Carly? Thinking about getting it so would give me another reason to go ahead and purchase.
- Number5
Bulb Warning Light!
I think the bulb warning light will reset itself as soon as the faulty bulb is eliminated.
All of the rear, fog and indicator bulbs are the same, so just buy a spare and swap the new one into all locations one by one until you identify which one was faulty. However, saying that, I've got a bulb fault at the moment and I've tracked it to the bulb holder (not the bulb) in the outer half of the rear light.
I've moved it to the fog light for the time being until I can replace it, so visually everything looks right at the back still.
Also bear in mind that the Z4 has the 'next function' facility, where by if the indicator fails for example, the rear light will flash instead. The lamp next to the fault takes on the job of the failed bulb, which can at time be confusing !
Bulb Warning Light!
I've replaced my fog lights with covers so they're not connected anymore...do you think it could be this then? Cheers.Number5 wrote: ↑Tue Jul 18, 2017 8:24 am I think the bulb warning light will reset itself as soon as the faulty bulb is eliminated.
- Joycey
Bulb Warning Light!
I've done the same with the fogs and mines not illuminated. To answer your first question, yes Carly can turn off bulb checks. But you must have one out somewhere, you sure its not the little inner halo ring they are very sensitive.
Bulb Warning Light!
It probably could be. I haven't checked them yet. Is it a big job to get to the front bulbs?
- Joycey
Bulb Warning Light!
Not really, Access is through the wheel arch liner (you'll see a little cover to remove), easier with the wheel off. If it is the halo bulb they're £35 from BMW its a sealed halogen bulb in a holder. Or do what I'm about to do.
Order two very bright LED's to replace these 10w bulbs and turn off the lamp indictor function
Bulb Warning Light!
Nah Joycey, mine did this, all bulbs working perfectly- i took the bulb out the dash for the bulb warning
18 Z4s owned to date.
Current: 2.5i Titan silver
Bulb Warning Light!
Good plan matey! Are you going to turn it off using Carly?Joycey wrote: ↑Tue Jul 18, 2017 9:54 am Not really, Access is through the wheel arch liner (you'll see a little cover to remove), easier with the wheel off. If it is the halo bulb they're £35 from BMW its a sealed halogen bulb in a holder. Or do what I'm about to do.
- Joycey
Bulb Warning Light!
Yeah I bought the software a few weeks back and picked up a carly adapter the other day. Needs to be a gen 2 adapter to access all the functions. £48 for the software and £68 for the adapter. First impressions are very good. No faults showing on my normal reader but carly found 25.idej_jedi wrote: ↑Tue Jul 18, 2017 10:36 amGood plan matey! Are you going to turn it off using Carly?Joycey wrote: ↑Tue Jul 18, 2017 9:54 am Not really, Access is through the wheel arch liner (you'll see a little cover to remove), easier with the wheel off. If it is the halo bulb they're £35 from BMW its a sealed halogen bulb in a holder. Or do what I'm about to do.
- mac27040
Bulb Warning Light!
does carly tell you which bulb is faulty, DIS v57 does, navcoder can deactivate check bulbs
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
