Transmission fluid change
E85
Re: Transmission fluid change
Post by E85 » Tue May 05, 2009 5:03 am
be sure to report back to let us know. i'm curious if you can really feel that much difference?
2003 Z4 3.0 w/ Sport Package & Premium Package
Aliv6
Post by Aliv6 » Tue May 05, 2009 10:18 am
This is something i want to do! The M gearchange is the WORST i've exprienced! And thats conparing it to TVR's, Lambo's, Race Cars! lol...Building a good picture here.
2007 Z4MC & 2004 Mk2 Clio V6
Adam D
Post by Adam D » Tue May 05, 2009 2:03 pm
Mines now done and has had the standard MTF-LT1 fluid has been changed for some nice new MTF-LT2. My car has done 38,900 miles and is a April 2003 build. The gearbox yellow label states it is filled with MTF-LT1 and is a lifetime fluid that shouldn't be changed.
I wasn't expecting a huge difference to be honest, but blimey its like a different gearbox now. Selecting 1st from a standstill just snicks in firmly but cleanly and the resistance/baulking when shifting gears has been improved no end. 1st - 2nd can still need a little bit of patience to do smoothly but I still have the CDV in place, its better though. The reluctance to select reverse has also gone, hopefully as the oil works its way around it will loosen up even more but so far im very happy indeed at this early stage :D
Its really made the car much more enjoyable - my advice get it done and use the genuine oil MTF-LT2.
Silver Grey 2007 Z4MR which needs to be driven more :evil: :P :cool: :D :thumbsup:
E85
Post by E85 » Wed May 06, 2009 4:23 am
great to hear Adam D. i'm sure you can't go wrong with either Redline and OEM
Adam D
Post by Adam D » Wed May 06, 2009 12:55 pm
I will put some miles on the car with the new fluid and update any further improvements/degredation.
T2FFN
Post by T2FFN » Sat Jul 04, 2009 4:14 pm
How much did/will this cost at an indy garage?
3.0i
Leon.
Post by Leon. » Fri Dec 18, 2009 10:19 pm
Looks like I'll be doing this too then...
I have an Alpina Roadster, says the fluid never needs to be changed, but seems this is not entirely true! I changed the trans fluid on my last car 3 times and it kept it fresh, which is why I was interested in doing the job :thumbsup:
Kaide
X-Box live gamer tag: cjstaw
Post by Kaide » Fri Mar 12, 2010 3:56 am
Digging up an old post... :?
How much fluid did it take to fill? I figure I'm gonna use MTF LT-2.
03 Z4 3.0i / 6 Speed / Dinan CAI / Dinan Ram Air / Dinan Stage 2 Software / Dinan Strut Bar / My car
98 Honda Superhawk / 101whp
"Life is a game of relationships"
Kaide
Post by Kaide » Fri Mar 12, 2010 7:40 pm
I've been searching near and far and cant find any how to for changing the fluid. I'm assuming the yellow circled plug is the drain and the blue is the fill plug, but how do you actually get the fluid into the box? I've heard of needing some kind of pump, and the car has to be level. Also, have any of you added any additives? Any advice is greatly appreciated! :driving:
Leon.
Post by Leon. » Sat Mar 13, 2010 12:52 am
One thing to do is to make sure the filler bolt comes off before you empty the oil out!
On my MR2 i used to use a length of 0.5" tubing and a funnel and fill from the top of the engine bay, once I'd poked the tube into the fill area. If you can get the car on ramps you may be able to fill direct, not sure though as I've not got on my hands and knees yet. Not sure about pumps but sure they'd work...
Shipkiller
Post by Shipkiller » Sat Mar 13, 2010 1:05 am
Yes, the lower one (in yellow) is the drain plug.
As leon says, make SURE you can loosen the fill plug before you start draining.
As for getting the new fluid in the transmission, you will need a pump or some other way to get it in... There are several types and makes.
No additives. Just straight fluid out of the bottle. Fill until you get fluid out of the fill hole.
Drives 2008 Z4MC (His) & 2003 Z4 Roadster (Her's)
Tim82
Post by Tim82 » Thu Mar 18, 2010 8:02 pm
has anyone used Castrol SMX S 75w-85?
It's readily available in the UK in units of 1litre
However, word from Opieoils.co.uk is Fuchs Titan Sintofluid SAE 75w-80 is stock oil.
2003 3.0 roadster
repairs so far: 4 springs, 1 alarm bonnet sensor, 1 driver's side window regulator
craig3.2
Post by craig3.2 » Thu Mar 18, 2010 11:01 pm
Any one have any idea/info on what this should cost,in the uk/by an independant garage,using either redln or bmw stuff?
cheers :driving:
Interlagos Blue M RDSTR,2008. Logic7 dsp Hifi;satnav,stubby,htd seats,etc,etc.
Black 2005 3.0i NOW SOLD(and missed)
handy_andy_100
Post by handy_andy_100 » Mon Jun 13, 2011 8:53 pm
Hoping to source the oil asap and do the job on the weekend.
Can someone advise on how much oil i'll need? I have a 2005 3.0.
Also...... while i'm at it, what about the differential? What oil should i use? and how much to order?
One more for luck........... any recommendations as to where to order from in the UK?
Cheers,
Andy
bigbacon
Post by bigbacon » Thu Nov 17, 2011 1:53 am
What size allen key is needed to remove the fill/drain for a 3.0?
Who is online
Users browsing this forum: No registered users and 3 guests
