Upgrade Audio but keep original head unit
Smallsy99
Post by Smallsy99 » Sat Mar 05, 2022 1:48 pm
So I have a 2004 E85 2.5SI and currently I’m using a radio receiver for my music that bluetooths to my phone. This is okay but the quality and volume are not great at all and I also loose the signal if I go to a new area…!
What I ideally want to achieve is to have either USB or Bluetooth capabilities for the car but ideally I want to keep the original head unit in place. Purely as I find adding in a stereo just doesn’t look right. I have a stereo from my old car so I can still do that. I just wondered if there was a means of doing what I’d like. I have looked into upgrading amps etc but nothing solid and I’m not sure what I’m looking for.
I appreciate this maybe a bit bespoke but thought I’d chuck this question out there!
Jakg
Post by Jakg » Sat Mar 05, 2022 2:08 pm
USB is probably doable with a Grom or something.
Bluetooth will be easy using a BlueMusic unit (and cheap).
sw4nny
Post by sw4nny » Sat Mar 05, 2022 2:12 pm
Try one of these
Worked for me and easy fit once you get the centre vents out to enable head unit removal.
Smallsy99
Post by Smallsy99 » Sat Mar 05, 2022 3:34 pm
Thank you for this - what setting will it takeover on the stereo? I have Radio, CD etc but not sure what would show up with this added?
sw4nny
Post by sw4nny » Sat Mar 05, 2022 3:44 pm
Smallsy99 wrote: Sat Mar 05, 2022 3:34 pm Thank you for this - what setting will it takeover on the stereo? I have Radio, CD etc but not sure what would show up with this added?
Use the aux setting on head unit
Smallsy99
Post by Smallsy99 » Sat Mar 05, 2022 4:16 pm
I don’t believe I have that option available
mr.tourette
Post by mr.tourette » Sat Mar 05, 2022 5:50 pm
Smallsy99 wrote: Sat Mar 05, 2022 4:16 pm I don’t believe I have that option available
Aux doesn't appear until you have something in place the head unit recognises as an aux input
Smallsy99
Post by Smallsy99 » Tue Mar 15, 2022 7:05 pm
Hey just to say this came today and I fitted it. Works perfectly!! Thank you very much!
sw4nny
Post by sw4nny » Tue Mar 15, 2022 7:25 pm
:thumbsup:
Glad it all works fine.
richyrich
Post by richyrich » Mon May 16, 2022 3:23 pm
ah, this looks great, thanks sw4nny. Did you leave the bluetooth dongle behind the dash? Did you set the mic up? Many thanks, Rich.
Registered 2004. Bought May 2007 at 10,000 miles. May 2022 now at 104,000 miles.
Smallsy99
Post by Smallsy99 » Mon May 16, 2022 5:07 pm
I managed to get it all hidden behind with no real issue. The only struggle was making sure the wiring look fed back through the metal hole. Also the connection was white sensitive so when I put it all back together I was only getting sound out of the left hand speakers. Fiddled around and got this solved.
The mic I routed okay - it’s a bit visible but works alright for the money
