After reading hundreds of posts on multiple forums I have come to understand there are 2 different part numbers being used to add an aux jack in the Z4
The BMW Mini Jack part number is 82110153367
The BMW 3 series E46 part number is 82110149389
Can someone please clarify if both of these will work? What is the difference and which one should I order to keep my install simple?
Thanks for any help...Ian
Help Please-which aux jack
- Stromtech
2004 3.0i 6 speed, Sterling Grey, Premium, Sport and Convenience packages
- Redzedfour
Re: Help Please-which aux jack
The two part numbers you have quoted are not showing anything up on Realoem.
But this one 65.12.0.153.502 does as it is the one i had fitted in both my Zed's hope that is of some help
http://www.realoem.com/bmw/partxref.do? ... showeur=on
- Stromtech
Interesting that the numbers are different. I have been doing my look up on the BMW of Atlanta and BMW of Palm Springs web sites and they are coming up with the numbers I posted in my query. Perhaps the USA numbers are different from the UK. Adds to the confusion.Redzedfour wrote:The two part numbers you have quoted are not showing anything up on Realoem.
Thanks...Ian
- Stromtech
Yesterday I installed the mini Jack #82110153367. It cost $30 from BMW of Palm Springs. It has a 12 pin socket and fits perfectly into the wiring socket.
Some facts:
I can cycle the selection button on the radio and see 'AUX' regardless if the Iphone is connected.
I am using an Iphone dock cable that splits to both mini jack for the aux-in and USB for charging and it works perfectly
The sound is CD quality and sound levels match the radio output levels.
The docking cable I bought from ebay for $2.59 with free shipping from China:
http://www.ebay.ca/itm/USB-3-5mm-AUX-Au ... 27b7582ac8
Hope this helps...Ian
Some facts:
