soft top lubrication
Requests for how-to's go in here
Re: soft top lubrication
Postby Swashbuckles - Sat May 28, 2011 1:51 pm
I do mine every month regardless, used to have a Z3 and left that to every quarter and paid the price. I use WD40 on all hinges and rollers, also the front claw catches. I use a very light Vaseline coating on the rubber seals all thevway round, once dry I also use normal boot polish on a rag to give a protective film, i only apply a light covering.
Additional I use boot polish on my seats, it keeps them in brilliant condition and can remove belt buckle etc scuffs and scratches.
Dave :driving:
Swashbuckles
Country: United Kingdom (uk)
Postby ZED_NOT_ZEE - Thu Jun 02, 2011 2:27 pm
Swashbuckles wrote:I do mine every month regardless, used to have a Z3 and left that to every quarter and paid the price. I use WD40 on all hinges and rollers, also the front claw catches. I use a very light Vaseline coating on the rubber seals all thevway round, once dry I also use normal boot polish on a rag to give a protective film, i only apply a light covering.
Dave :driving:
Probably not a good idea actually. WD40 is a water disperserant, not a lubricant. It also evaporates into a sticky residue usually compounding the issue. 3-in-1 is an oil, not a grease.Stick with an actual grease such as lithium grease or white grease (which is typically what is used for convertible tops, power windows, and hinges.)
Also Vaseline on rubber seals is a definite no-no. Vaseline is petroleum based and will actually 'eat' through rubber and latex causing small holes and eventually rips/tears. What you want is a silicone based lubricant.
Z4 3.0i SMG - Sport/Prem/Nav. Gray on Red (year-round beater)
e46 M3 SMG II - Cold/Heat/Lux. Black on Black (summer beater)
e36 M3 5-Speed - Cold/Lux. Black on Black (winter beater)
Suzuki GS500F - No options. Black/White (city beater)
ZED_NOT_ZEE
Country: Canada (ca)
Previous
Return to REQUESTS
Who is online
Users browsing this forum: No registered users and 1 guest
cron
