Engine management light :s
RoyS
Post by RoyS » Sun Apr 20, 2014 6:05 pm
Hi guys, as you may know I'm pretty new to z4's, not even had mine a week yet and the problems start :cry: . Well it's the first time I've done a long drive in her (200 miles) and all was good, until I was about 3 miles from home. There are a series of round abouts linked my national speed limit A roads, I must admit I was driving her fast between these but nothing too excessive. Then after coming out of the final one and putting my foot down a bit, the engine management light comes on and the exhaust sounds really different, also she is lacking quite a bit of power. In the control systems (on the idrive) it comes up with no faults but seems to vibrate when I press on the pedal in the low rev range, like I said I was only 3 miles from home so I gently took her there. Does any one have any idea what this could be? I'm not mechanically minded so I have no clue what so ever, as far as I'm aware it is a standard exhaust oh and it's a 30i.
Wa'ya
Re: Engine management light :s
Post by Wa'ya » Sun Apr 20, 2014 6:36 pm
Sounds like you went into limp mode, if you have a code reader I would run a test and see what is displayed.
You could also read this to see if it sounds like the problem your having
http://www.e90post.com/forums/showthread.php?t=486201
if it is the problem it's a pretty easy fix
Yep got a :whip:
RoyS
Post by RoyS » Sun Apr 20, 2014 6:58 pm
Thanks, one of my friends may have a code reader, I'll start asking. How much will BMW charge just to have a look, or don't I want to know :/ is there anyway to upload videos on here so people know what it sounds like?
Sent from my iPad using Tapatalk
Wa'ya
Post by Wa'ya » Sun Apr 20, 2014 7:19 pm
Not sure how much they charge LOL so far I've avoided the stealers hmmm I mean dealers LOL, I just went through cleaning my vanos and finding one had a fault if cleaning does the trick it doesn't cost you anything but time. The one I replaced cost me $120 and it took about 30 minutes.
But as far as posting pictures and videos check out the newbie section for all the how to's
http://www.z4-forum.com/forum/viewtopic.php?f=11&t=30
Yep got a :whip:
RoyS
Post by RoyS » Sun Apr 20, 2014 8:23 pm
Well my friend came round and plugged his machine in came up with "P0306"cylinder 6 misfire detected. What does this mean and will it be an expensive fix?
Wa'ya
Post by Wa'ya » Sun Apr 20, 2014 8:28 pm
Yep got a :whip:
MHZ4C
Post by MHZ4C » Sun Apr 20, 2014 8:53 pm
Very useful website. Thank you Wa'ya.
Wa'ya
Post by Wa'ya » Sun Apr 20, 2014 9:01 pm
No worries man :thumbsup:
Yep got a :whip:
RoyS
Post by RoyS » Sun Apr 20, 2014 9:25 pm
Thanks :) I'm going to move the coil packs around tomorrow see if the problem follows if not change the plugs
DPG
Post by DPG » Mon Apr 21, 2014 8:25 am
Certainly sounds like a coil. Fingers crossed
RoyS
Post by RoyS » Mon Apr 21, 2014 3:58 pm
Well switched the coils over, same cylinder problem. Tried moving spark plugs over no change,
looks like garage tomorrow :/
mattstav
Post by mattstav » Mon Apr 21, 2014 4:05 pm
sounds exactly like what happened to my 1 series and it was the coils. Had them replaced and it was like a new car again.
2010 Z4 23i SDrive, Auto, Black Saphire, Pure White Interior Package, Stubby, SmartTop and LCI Repeaters
Wa'ya
Post by Wa'ya » Mon Apr 21, 2014 5:04 pm
RoyS wrote:Well switched the coils over, same cylinder problem. Tried moving spark plugs over no change,
Buggers Roy, not sure I wouldn't put new NGK spark plugs in just to try, but I hope you get it sorted man!
Yep got a :whip:
RoyS
Post by RoyS » Mon Apr 21, 2014 5:39 pm
It's still under warrenty, they should let me bring it to a garage down here surely? Just the problem is I bought the car 200 miles away would that be a problem at all do you think?
Wa'ya
Post by Wa'ya » Mon Apr 21, 2014 7:14 pm
Still under warranty, I'd have a dealer fix it! :) My 07 is way out which is why I sped so much time figuring out my own problems.
Yep got a :whip:
