Battery Symbol
Battery Symbol
I've had a battery symbol come up on my dash twice now, about a month apart, if I've had the ignition on for a minute or so but not started the car.
Presumably this means it's new battery time. Could it be anything else?
It's a 2010 35i S drive on 83,000 miles and is definitely the original battery.
Are these the sort of battery that requires dealer registration? Any idea of cost? It needs to be a genuine item as I'm still paying extended warranty.
Thanks.
Thanks.
- Chris_D
Battery Symbol
Get it replaced under warranty.SGL3JJW wrote:I've had a battery symbol come up on my dash twice now, about a month apart, if I've had the ignition on for a minute or so but not started the car.
Thanks.
Battery Symbol
Batteries are explicitly excluded even though it's the comprehensive warranty, sadly.
- Chris_D
Battery Symbol
Looks like ur gonna have to shell out for a new battery then. Unless ur alternators on the way out and not charging ur batterry adequately.
Battery Symbol
Do you need to have BMW code an E89 battery to the car though?
Alternator is fine. 14.4v across the battery with car running.
Cheers.
Cheers.
Battery Symbol
Did someone somewhere mention that Halfords can now supply and code batteries?
Also read somewhere on a different car BMW forum, so long you replace with exact same battery, no need to code?
Battery Symbol
Yes Halfords do batteries, AGM 70ah, own brand (which are Yuasa), £149 +£25 fitting and coding.
Just had one fitted.
Battery Symbol
I have the same issue, did a google search, everyone is trying to sell me a very expensive AGM battery but I read on other forums that his is not necessary, an inexpensive S5 or even S4 battery will do apparently?
Does anyone know what the original spec was for a 2012 Z4 ROADSTER - 20i sDrive M Sport 2dr Auto?
Battery Symbol
Well they are AGM for a reason, probably to cope with the demands of the power roof, steering, etc and if it's a start /stop car.bikbergen wrote:I have the same issue, did a google search, everyone is trying to sell me a very expensive AGM battery but I read on other forums that his is not necessary, an inexpensive S5 or even S4 battery will do apparently?
The battery I bought says on the side good for 380,000 stop starts.
Why go cheap on a valuable car with lots of electrical gizmos.
Battery Symbol
Had the same issue recently, swapped the four year old Yuasa AGM battery for the old trusty Bosch S5 and all is well on my E85 2.5i.
- Mr Tidy
Battery Symbol
Before I became enlightened to the world of straight 6 petrol BMWs I had an E87 facelift 123d with stop/start (I know, I'm sorry)!
Anyway soon after the starter motor died (£600ish) the battery light came on. Great, I thought - at least it told me before it died!
But when I looked into replacement costs I was less impressed as it was an AGM battery and needed to be coded - so another £250 wallet lightener! (It lasted nearly 6 years IIRC).
And soon after that I got my first Z4, so the E87 became someone else's problem (before the N47 engine wrecked itself due to the cam-chain issue)!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Ewazix
Battery Symbol
AGM is a waste on the e85 anyway and lots of people ruin them with a standard charger which quickly kills them. I've got the original BMW 2003 date stamped battery in my e85 and it's still going strong (but surely can't last MUCH longer, can it?).Devon Eleven wrote:Had the same issue recently, swapped the four year old Yuasa AGM battery for the old trusty Bosch S5 and all is well on my E85 2.5i.
If AGM was original fit then stick with it, if not then you are unlikely to see any advantage in an AGM for the extra cost.
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
- Mr Tidy
Battery Symbol
Agree entirely with avoiding AGM if it was not original fit!Ewazix wrote:AGM is a waste on the e85 anyway and lots of people ruin them with a standard charger which quickly kills them. I've got the original BMW 2003 date stamped battery in my e85 and it's still going strong (but surely can't last MUCH longer, can it?).Devon Eleven wrote:Had the same issue recently, swapped the four year old Yuasa AGM battery for the old trusty Bosch S5 and all is well on my E85 2.5i.
But just to avoid any confusion the OP has a 2010 E89, so I'm guessing that did come with AGM and therefore still needs AGM.
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
