Gearbox oil leak
martins
Gearbox oil leak
Post by martins » Tue Dec 27, 2016 5:29 pm
Hi,
While getting the car MOT'd and it's HPFP fixed, the dealer pointed out an oil leak under the car. This seemed very reminiscent of last year where under warranty the dealer fixed the seal between the gearbox and engine, so I asked them to have a look, and they diagnosed it as the DCT gearbox mechatronic cover gasket (Part http://www.realoem.com/bmw/enUS/showpar ... 8607842856).
This afternoon I decided to take a closer look myself:
Yep, evidence of oil:
Not a lot of evidence of oil from the gear box:
Nor here:
But there is engine oil coming from the engine end (again I guess!)
I mentioned this to the dealer and they said that parts replaced under warranty have no further warranty one the warranty has expired. Does that sound right?
Chris_D
Gearbox oil leak
Post by Chris_D » Tue Dec 27, 2016 5:47 pm
Thats def ur main seal again. My e46 m3 had a main seal failure and it cost me megabucks to get sorted. The gasket is cheap but the labour involved to replace it is v time consuming.
Not sure re ur warranty issue but if ur not covered for it go to an indy not a main dealer. U will just get ur pants pulled down.
Good luck!
Edit bad spelling lol
firebobby
Gearbox oil leak
Post by firebobby » Tue Dec 27, 2016 5:50 pm
Sounds wrong, they changed a part... supposedly and it's failed within a year of fitting, can't be right :thumbsdown:
Did they change it last year or just clean the area ??
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Smartbear
Gearbox oil leak
Post by Smartbear » Tue Dec 27, 2016 6:00 pm
firebobby wrote:Sounds wrong, they changed a part... supposedly and it's failed within a year of fitting, can't be right :thumbsdown:
I think the op has the correct info about the warranty repair, I think the customer has to make a financial contribution to the cost for the part concerned to be under warranty in its own right :roll:
e85 3.0si sold
VRSteve
Gearbox oil leak
Post by VRSteve » Tue Dec 27, 2016 7:23 pm
The OP is right, if the warranty runs out on Fri and something is fixed on Thur its only covered until Fri, that's just the way it works.
///M|Silver Grey|Black Leather|BT|Nav|DSP|Heated Seats|PDC|Stubby|Turner Limiters|Turner Rear Top Mounts|Bilstein B12|Powerflex ARB Bushes|Powerflex Lollipops|M-Track|
SOLD
firebobby
Gearbox oil leak
Post by firebobby » Tue Dec 27, 2016 7:41 pm
That makes sense, but they did tell him it was a totally different gasket from what appears to be leaking. This is what they say was repaired last year (main seal) which appears to be leaking. Was it repaired or did they just clean the area ??
Toyota MR2 NA 1995
Mini 1000 1981
VRSteve
Gearbox oil leak
Post by VRSteve » Tue Dec 27, 2016 7:44 pm
firebobby wrote:Was it repaired or did they just clean the area ??
Well that I suspect you will never know
SOLD
firebobby
Gearbox oil leak
Post by firebobby » Tue Dec 27, 2016 7:55 pm
True :)
Toyota MR2 NA 1995
Mini 1000 1981
Maniac
Gearbox oil leak
Post by Maniac » Tue Dec 27, 2016 7:56 pm
I've heard a few reports of this on DCT cars (BMW but not limited to Z4s).
Not seen it on mine but will be checking when weather improves. Mind, I had my entire gearbox replaced at year 1.
martins
Gearbox oil leak
Post by martins » Thu Dec 29, 2016 9:32 am
Thanks for the comments guys. To be honest, I'm pretty unbothered about the engine oil leak, it's easy to buy a bit more oil and a hell of a lot cheaper unless it's raining oil out of the bottom! Looking at the tray under the engine there was a bit of gearbox oil on the tray but no sign of drips. If the gearbox gets low on oil, will it detect it and show an engine code? That's my worry that the gearbox will drain it's oil and lunch itself!
