what is that metal clicking and popping sound whenever i change gears?
P to R, click.
P to D, pop.
R to D or D to R, huge jolt and clunk.
brake to full stop, click.
- NickDE
Automatic ?
My auto doesn't make noises like that
Darkness gone, go Darknes2, go Frozen, go Tronic
- Wrs
Valve within your rear silencers.
Gone - Black Sapphire Z4 E89 35is
Gone - Midnight Blue Z4 E85 3.0si
So other than the 'huge jolt' which sounds like a 'massive' problem... (I'm guessing you don't get a 'huge' jolt but that you feel a slight movement as drive train slack is taken up) I'd suggest that your car is perhaps DCT? If so, this sound is normal and is the mechatronics in the transmission, valves, solenoids etc that control flow of fluids to clutches and so forth. Again, entirely normal, especially when the DCT is inches away from you. Just think of it as it buckling its belt ready to go! If not a DCT and a normal auto then I can't help as I've not owned one of the normal auto boxes and therefore I couldn't be certain what noise levels to expect from its mechatronics.
ok thanks. yes it's DCT. i should add that most of the metal clicking and popping sounds like it's coming from the brakes. i have to admit it's a bit unsettling.Maniac wrote: ↑Fri Apr 07, 2017 12:52 pmSo other than the 'huge jolt' which sounds like a 'massive' problem... (I'm guessing you don't get a 'huge' jolt but that you feel a slight movement as drive train slack is taken up) I'd suggest that your car is perhaps DCT? If so, this sound is normal and is the mechatronics in the transmission, valves, solenoids etc that control flow of fluids to clutches and so forth. Again, entirely normal, especially when the DCT is inches away from you. Just think of it as it buckling its belt ready to go! If not a DCT and a normal auto then I can't help as I've not owned one of the normal auto boxes and therefore I couldn't be certain what noise levels to expect from its mechatronics.
My auto is also silent, no untoward noises.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Pastry
It's a shame the rest of the car rattles like a bag of bolts Fred
991 Carrera 2S
Now gone:
2010 Z4 23i Msport and a 3.0i
Now gone:
I have a DCT and get the clicks and clunks too; I'd just assumed it was the gearbox pre-selecting the next gear on the unused clutch?
10-plate E89 35i, Deep Sea Blue
67-plate F15 X5 35d, Space Grey
Not when you have a tongue and grove dashboard it don't
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
