remove Drivers front wing
How-To articles are in here.
koolchris99
Post by koolchris99 » Sun Jan 15, 2017 6:26 pm
anyone got a DIY guide to removing the drivers front wing. Ive been hit twice on it and time to replace.
Chris
Esienmann Race Exhaust, Gruppe M, Carbon Leather interior, Hardtop, CSL's, Eibach Pro springs, EBC discs, EBC greenstuff pads, Tarox Brake lines, Motul 5.1 fluids, powerflex bushs, rogue engineering mounts, Stubby, Aux, Cruise Control, Sound Generator mod
Smartbear
Post by Smartbear » Sun Jan 15, 2017 6:38 pm
koolchris99 wrote:anyone got a DIY guide to removing the drivers front wing. Ive been hit twice on it and time to replace.
Chris
The wings just unbolt, possibly wheel arch liner off to access all the fixings?
e85 3.0si sold
goldbcfc
Post by goldbcfc » Sun Jan 15, 2017 6:57 pm
Mine was an absolute problem. Of courrse you work your way around all the bolts to remove then you get to the tricky ones inside the door. I found it easier to take the indicator out then you can reach in fine otherwise its a bit of a stretch from the brake disc side. You need to pull back part of you lower skirt to acces the two lower bolts to wing. All my bolts cam out easy apart form 1 to the door side and 1 under the skirt. I messed about for ages the bolts wasnt budging. Why on earth bmw use those stupid torx stlye bolts its easy to round them off. So out came the angle grinder the wing came off 5 mins later :thumbsup:
srhutch
Moderator
Moderator
Post by srhutch » Sun Jan 15, 2017 9:08 pm
Changed mine coming up 4 years ago :o
viewtopic.php?f=2&t=52394
Easy enough job, but as said you need to remove the side skirt first to get to the bottom two screws. Likewise I removed the indicator to access the two inner screws.
You also need to partially remove the front bumper to get to one of the screws.
I had no issue with any fixings though.
