What size 19" wheels can i fit on a standard z4
Alloy wheels and tyre discussion
Dr-Jon
Post by Dr-Jon » Mon May 08, 2017 8:31 pm
as the topic states, i would like staggered, 9" rear 8" front or 9.5" rear 8.5" front but what offset will i need ? will i need spacers
2010 2.3 Auto with paddles in black with koral red leather and Sat Nav, heated seats, and steering wheel. stubby aerial
mr wilks
Post by mr wilks » Mon May 08, 2017 9:21 pm
Your question is hard to answer with a definitive answer but if you aim around et30 front / et 40 rear & try not to go over those then you should be fine within reason . ( if you go over spacers could be needed )
If its OEM you are after then new shaped 3s & 5s will fit / if its aftermarket then the wheels offered up on the websites should be suitable for your car .
CMwheels are well used by BMW forum members as are BMautosport . LKperformance is also a good place to use as a search for potential wheels :thumbsup:
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
