19" alloys
Alloy wheels and tyre discussion
Woodmic
19" alloys
Post by Woodmic » Fri Aug 11, 2017 5:26 am
Hi l have recently purchased a late 2009 z4 coupe l would like to fit 19" alloys and tyres but do not want to upset the cars handling or have problems with tyres rubbing thanks
Michael
mr wilks
19" alloys
Post by mr wilks » Fri Aug 11, 2017 11:22 am
Aim for 8j front , 9j rears & et numbers around 40
8.5j fronts , 9.5j rears will be more common & will work but definitely don't go under et40 for the fronts , rears will be fine down to low 30s
Once wheel sizes are known choose the tyre sizes to suit & don't just go off whoever is supplying the wheels :wink:
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
Buckz
19" alloys
Post by Buckz » Fri Aug 11, 2017 11:33 am
mr wilks wrote: Fri Aug 11, 2017 11:22 am Aim for 8j front , 9j rears & et numbers around 40
I've got 18's
18x8.5 front et30.. 225 rubber
no rubbing :o
https://www.dropbox.com/s/8gsxy7j26sa1h ... 3.jpg?dl=0
jamie_z4
19" alloys
Post by jamie_z4 » Fri Aug 11, 2017 11:36 am
Buckz wrote: Fri Aug 11, 2017 11:33 am
I've got 18's
no rubbing :o
ive got et30 18x10J rear 225 rubber
no rubbing :o
:rofl:
18 Z4s owned to date.
Current: 2.5i Titan silver
Buckz
19" alloys
Post by Buckz » Fri Aug 11, 2017 11:37 am
jamie_z4 wrote: Fri Aug 11, 2017 11:36 am
I've got 18's
no rubbing :o
no rubbing :o
:rofl:
rears are usually fine on z4's it's the front that causes the problems :evil:
jamie_z4
19" alloys
Post by jamie_z4 » Fri Aug 11, 2017 11:38 am
Buckz wrote: Fri Aug 11, 2017 11:37 am
I've got 18's
no rubbing :o
no rubbing :o
:rofl:
true - im on a 205 40 18 front 8.5J et25 - seems i could have got away with a 215 then going off your fronts :)
Buckz
19" alloys
Post by Buckz » Fri Aug 11, 2017 11:40 am
jamie_z4 wrote: Fri Aug 11, 2017 11:38 am
no rubbing :o
:rofl:
probably, keep in mind that I'm stock sport suspension.
I have a feeling that on eibachs it'll rub a little and I might have to go for 215's up front. We'll see next year :rofl:
jamie_z4
19" alloys
Post by jamie_z4 » Fri Aug 11, 2017 11:42 am
Buckz wrote: Fri Aug 11, 2017 11:40 am
ohhhhh yea so you are.
Yea think i'll stick with me 205s then :)
You might get away with trimming your arch liner
Joycey
19" alloys
Post by Joycey » Fri Aug 11, 2017 11:53 am
My new fronts are ET37 going to be snug under there :rofl:
jamie_z4
19" alloys
Post by jamie_z4 » Fri Aug 11, 2017 12:10 pm
Joycey wrote: Fri Aug 11, 2017 11:53 am My new fronts are ET37 going to be snug under there :rofl:
I fitted the 313s on mine with coilovers on a 225/35/19 which are the same specs as your style 225M wheels with no issues even at my height.
mr wilks
19" alloys
Post by mr wilks » Fri Aug 11, 2017 12:50 pm
I've got 18's
no rubbing :o
OP has asked about 19s not 18s , does make a difference depending on tyres , springs , roadster , coupe etc , so many factors as discussed many times . there is no one size fits all Zs magic formula :roll:
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Buckz
19" alloys
Post by Buckz » Fri Aug 11, 2017 1:47 pm
mr wilks wrote: Fri Aug 11, 2017 12:50 pm
I've got 18's
no rubbing :o
over-all the size is pretty much the same ? you go up in size and go down in sidewall?
his is a coupe, 3.0, sport. Same as mine ;)
mr wilks
19" alloys
Post by mr wilks » Fri Aug 11, 2017 2:08 pm
Buckz wrote: Fri Aug 11, 2017 1:47 pm
I've got 18's
no rubbing :o
Supposedly yeah , which is why i said once the wheel size & offset is known then you can decide the tyre size which is as important as the previous 2 sizes .
I said not to go under et 40 as the op specifically mentioned he didn't want rubbing :wink: which i interpreted as he'd rather not play the game of chance & end with the usual " it just rubs a very little when full lock or when i go over a certain hump in road " :cry: nothing worse imo
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
