Daytime Fog lights Poll
- Marlon
Fog lights in the daytime with good visibility - cool or not?
Gone: 3.0si 2008 E85
911 997 Carrera S
- Smartbear
As far as I'm aware, its illegal to use fog lights if its not foggy? I could be wrong
e85 3.0si sold
- srhutch
- Moderator
Always used to be illegal, unless it's changed due to DRL. Not that I ever found front fog lights blinding.Smartbear wrote:As far as I'm aware, its illegal to use fog lights if its not foggy? I could be wrong
- Paulj100
- PerryGunn
AFAIAA it's still illegal - DRLs are not fog lights, they're nowhere near as bright...srhutch wrote:Always used to be illegal, unless it's changed due to DRL. Not that I ever found front fog lights blinding.Smartbear wrote:As far as I'm aware, its illegal to use fog lights if its not foggy? I could be wrong
...not that I've ever heard of anyone getting done for it but is does give the boys in blue an excuse to pull you over if they want
Alpina Roadster S #320
* Quaife ATB LSD * StrongStrut Braces * Turner RTAB Limiters * Gap-Tech RCH+ *
* Intravee & KCA-420i * Mini 0806 * Cheetah C550 * Stubby *
- Pastry
Would that be a wrong as a banana RobSmartbear wrote:As far as I'm aware, its illegal to use fog lights if its not foggy? I could be wrong
991 Carrera 2S
Now gone:
2010 Z4 23i Msport and a 3.0i
Now gone:
Fogs on when not foggy are cool, if you're 17 and in a stickered up Corsa...............IMO.
- Ducklakeview
It is illegal, under I think S226 in the highway code, and people have been issued with a fixed penalty for it. Depends on how much you wind up the copper that stops you...
IMO, it just looks stupid, and don't get me started on people who insist on whacking on the rear ones at the slightest hint of rain or fog. The rules are that they should be used when visibility is 100m or less, and turned off when it clears..
Mike
Edit; found it
Rule 226
You MUST use headlights when visibility is seriously reduced, generally when you cannot see for more than 100 metres (328 feet). You may also use front or rear fog lights but you MUST switch them off when visibility improves (see Rule 236).
and
Rule 236
You MUST NOT use front or rear fog lights unless visibility is seriously reduced (see Rule 226) as they dazzle other road users and can obscure your brake lights. You MUST switch them off when visibility improves.
Mike
Edit; found it
Rule 226
and
Rule 236
- Smartbear
Even more wrong than a banana!Pastry wrote:Would that be a wrong as a banana RobSmartbear wrote:As far as I'm aware, its illegal to use fog lights if its not foggy? I could be wrong
e85 3.0si sold
Anyone using fog lights when it's not foggy is a c**t.
- Machine monkey
Still illegal. I run with dipped beams on almost all the time to help be seen. DRLs are in the works to be fitted.
- Ducklakeview
- Ducklakeview
Scooba_Steve wrote:Still illegal. I run with dipped beams on almost all the time to help be seen. DRLs are in the works to be fitted.
For some reason, my Zed thinks it's dark a lot of the time and switches mine on, damn stupid position for the light sensor next to the switch if you ask me!
Mike
That sensor should only be for the instrument dimming. I find it more stupid having auto to the left of off, would be better to the right of dipped beam.
