any windows users/experts
- bluespit
odd thing on our pc running windows 10, (use macs most of the time but need a PC for some work specific software)
PC working fine except... noticed yesterday that the START icon does nothing, the explorer icon and the search buttons do nothing either. when I say nothing what actually happens is you get the 'hang on I'm thinking' thing for a second or two and nothing else. Everything else works fine, virus scan works and detects nothing, PC health check is OK too.
This is generally why I use macs - they just seem to work
cheers
cheers
now I'm about to have more time I've suddenly got less toys to play with!
- Chris_D
try a system restore to an earlier date than when u noticed the anomaly.
i'd love to give up windows but the software i need for my business is tied to it sadly. Still using 64bit XP cos it's the only OS that plays nice with VP Hybridcad. drrrr
try a registry cleanup too. (NT reg opt tho dunno if that works with 10. otherwise CCleaner...)
- bluespit
ah should have said, did a restore but that failed after about 30 minutes.
mines for cad too - solid works and corel draw, but at least they work on windows 10
coz I can't get start to work I can't get to more 'dos' type commands!
- enzed4
Can you right click on the start button and select 'command prompt (admin)?
If not, Hold Windows key and X, choose command prompt (admin)
When you have the command window up, type sfc /scannow and let it run (might take a while), it will hopefully fix corrupted entries that are stopping your start (and other) buttons from working.
Good luck
Good luck
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
- bluespit
thanks enzed, ran the scan and it found no issues and I still have the problem
the right click I hadn't thought of though
- markeg
Managed to get rid of Windows, except for son's gaming machine and wife's laptop (she's a dinosaur though, so that's permissable...) Having said that I've supported Windows users for years, and whenever desktop components 'freeze' it invariably points to either a driver issue, network issue, registry issues or corrupted explorer.exe file.
Have you installed any new hardware or software components lately? Also, are your windows updates up to date? Virus and malware scanners running, and data files up to date?
previous: Alpina Roadster S, #108: gone
current: MB C-class
"veni, vidi, velcro - I came, I saw, I stuck around..."
current: MB C-class
- Zed Five
There appears to be a few fix options if you google 'windows button not working'
Why is it that people who can't take advice always insist on giving it?
E89 35is | BMW S1000rr Motorsport Ed.
- bluespit
Markeg. All updates done, nothing new installed and not used for emails so unlikely to pick up viruses, even so I have antivirus uptodate finding nothing.
Z5. I've looked on google and tried everything short of a full reinstall. Don't want to do that as the saoftware I use is not so easy to get hold of at home.
Most of what I use it for is accessible via desktop icons but that it doesn't work correctly is bugging me
Thanks though.
Thanks though.
- markeg
Have you tried a registry cleaner (CCleaner has been mentioned by Chris_D)? Also, have a look for the process explorer.exe in the process tab of task manager - you can click on it and select restart from the options. Does it run cleanly?
current: MB C-class
current: MB C-class
- DPG
Does it do the same logged on as a different user?
- Wylie1
Do you get the same logging in as a different user? I've seen same symptoms before (Win 8.1 though), but it was fine under other user accounts. I created a new user account, migrated files & settings & deleted the original faulty user account
Z4C 3.0si Sport 2008 | Alpine White | Black CSL'ish 19's
- Wylie1
Haha..... beat me to it!
- bluespit
Created a new account and same thing
I'll have a bash at the explorer thing tomorrow.
Thanks chaps
Thanks chaps
- DPG
If that's the case have you installed or modified anything?
Does it work in safe mode?
- DPG
Couple of other things to try
Powershell
Right click on the Start Menu button and open Command Prompt (Admin)
Enter PowerShell in the command line
Paste the following line in the Administrator: PowerShell Window:
Get-AppXPackage -AllUsers | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register “$($_.InstallLocation)\AppXManifest.xml”}
Wait for the PowerShell to execute the command (ignore a few red error codes)
Regedit
Go to Search, type regedit and open Registry Editor
Go to the following path:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ ImmersiveShell\Launcher
Click Edit, New, DWORD (32-bit) Value, and name it UseExperience
Double-click the newly created item and set the value to 0
Click OK, close the Registry Editor and then restart your computer
Powershell
Regedit
