nfbr's 2007 Ruby Black Z4 Coupé! Blog/Build-Thread
- nfbr
Re: My 2007 Ruby Black Z4 Coupé! Diary/Blog/Build Thread
Managed to find time the other night to get my technician John to have a look at the geometry alignment
Took a couple of photographs along the way.
Here it is on the 4-post ramp with the Hunter Alignment system...
Alignment system hubs clamped onto the wheels
Up in the air for a few adjustments - Rear camber and toe were out slightly
Rear end readings: Spot on!
I forgot to take a photo of the front readings, but all was spot on!
The toe was at 0˚05' on both sides, Camber at -1˚21' (L) and -1˚25' (R) - This is adjustable however we didn't have the correct tool for it, so this will be done again at a later date - Hopefully when I decide whether to go with new tyres, or new wheels and tyres!
Caster was a healthy 5˚01 (L) and 4˚51' (R) but isn't adjustable.
The car now drives miles better. Steering feels more direct and I have less pulling over lumps in the road.
Mega happy
Next up, a good clean.
Mega happy
nfbr's 2007 BMW Z4 3.0si Sport Coupé - Car Diary/Blog/Build Thread
Ruby Black - Steptronic - Champagne Merino leather.
I like taking Photos, Cars, Technology and Rock Music
- Dale_B
Good results mate makes such a difference having the alignment set up correctly.
- nfbr
At the weekend I finally got around to giving the car a good clean!
First up, A quick rinse with the pressure washer to get rid of any loose debris
Then a pre-wash, a rinse, then another wash using the good old two bucket method and a microfibre wash mitt
Another rinse and it's looking better already!
Next up was to clay the paintwork on the car, For this I used a medium Bilt Hamber clay and a home mix of clay lube.
Just a small area of the paintwork on the roof brought up this with just one pass! Looks like it hasn't been done before...
After 2-hours of claying, the paintwork felt a lot smoother, but needed brightening up a little
So, On the recommendation of a friend, I gave the car two coats of AutoSmart Platinum Polish. Very similar to AutoGlym Super Resin, but with far less powder.
After drying with an Ultra Plush Microfibre Drying towel, it was polishing time.
With the polish applied and removed, We're now onto the finishing coats! I've chosen to go for FinishKare FK1000P after a lot of recommendations on detailing forums.
FK1000P Applied
2-Coats later
Next up, The leather... Due to me having no seat cover and having worked on it quite a bit in the past few months, the drivers seat had got a little dirty.
For this, I opted to go for a leather cleaner and conditioner kit from Gliptone - Basically - Gliptone are a leather producer and one of the worlds finest leather dye/paint companies, so they know exactly what they are doing when they make their leather care products!
Needless to say, It came up absolutely beautifully and I'm now happy that the leather is protected and conditioned!
Another cool by-product of this stuff, is that my car now smells like a leather factory! Such a nice smell
Anyway - Here's a couple of finished pictures:
And a couple of beading pictures for those interested in how the FK1000P works with rain
Overall, I'm happy with the products that I've used, but I'm thinking maybe a little later on in the year, I'll have the paintwork professionally machine polished as there are unfortunately a number of marks that I'd like to get rid of and some areas on the bonnet where it looks like someone has made a poor and thoughtless effort of removing bird poop.
Next up, Hopefully discs and pads once they arrive with me from Italy
FK1000P Applied
2-Coats later
- Dale_B
That clay bar was fairly dirty! I can imagine the lower half of the doors and side skirt panels being even worse? Overall it's came out great
Any particular discs & pads you are getting for them to come from Italy?
- nfbr
Strangely enough, the only two surfaces that were this bad were the roof and the bonnet. Everything else was pretty good overall! The bumper, the tailgate, the skirts, doors and wings only needed one pass!Dale_B wrote:That clay bar was fairly dirty! I can imagine the lower half of the doors and side skirt panels being even worse? Overall it's came out great
Tarox 'D95' Discs (Heat Treated, Anti-Corrosion Treated , Countersunk Drilled) and Tarox 'Strada' Pads (moderate fast road use).Dale_B wrote:Any particular discs & pads you are getting for them to come from Italy?
They normally only offer their G88 (40-grooved), F2000 (Swirl Grooved) and Sport Japan (Drilled/Slotted) rotors to UK customers so I'm having the ones I wanted imported by Tarox UK
- Dale_B
Good choice ... You are certainly getting the zed into top shape that's for sure.nfbr wrote: Tarox 'D95' Discs (Heat Treated, Anti-Corrosion Treated , Countersunk Drilled) and Tarox 'Strada' Pads (moderate fast road use).
- nfbr
I've found some wheels that I really like (And can get Michelin Pilot Supersport Tyres for) too but I'm still umming and arring about taking the car away from the OEM+ looks that I normally go for
And I'm not too sure how it'd look with 19"s on the Eibachs or whether I'd need to change for the H&R's.
Probably not something that I'll be doing any time soon though.
- nfbr
After a quiet period in which I've been mostly chasing tail... I've received my made to measure stainless steel pipes!
My plan is to give the Coupé a little more aural presence by removing the centre silencer!
Here are the pipes:
And here's the offending silencer: (Photo borrowed from someone on Z-Post)
I'm gonna have a word with our Tech genius guy Wayne and get him to do me a little Drive Away video of the standard exhaust, Then keep my fingers crossed that I measured it up right, then re-measure it all again another two or three times before cutting and joining... Then get another video on the same road with the silencer bypass pipes fitted
An update maybe later this week on these.
Here are the pipes:
- nfbr
Saturday morning job: Get rid of the centre silencer!
First up, Here's the silencer...
Cutting the old one off. I used an air speed saw for this. It took quite a while, but wasn't difficult.
With the four pipes chopped, An axle jack saved me from having a sore foot...
Comparing the silencer with the two replacement pipes - Weight wise, around 2kg has been saved - I quite simply couldn't believe how heavy that tiny little silencer was!
Pipes in place sleeved over, sealed with silicone and fastened up with Mikalor SupaClamps
And finally the finished thing:
First impressions: Driving around normally there is absolutely no increase in drone or any horrible resonance whatsoever.
The tone of the exhaust has changed slightly and if anything feels a little 'deeper' than it was before.
Volume wise, there's a little difference, the car sounds a bit more like it should have done from factory, but it in no way sounds like an aftermarket exhaust.
I'm quite happy with it so far.
Here's a quick crappy rev-up video I took with my iPhone.
I need to get a start on mine. Have you chosen the wheels yet?
3.0si Sapphire Black Coupe
- nfbr
Kind of... I'm not sure though. Plus other things are 'diverting' my funds at the moment... Which I'm not too sure whether it's a or a yet...
Same here, a refurb is half the money toward decent reps and my wheels def need doing. Then there is the added cost of spacers. I've just bought h&r springs and I'm keen to get it all sorted.
Did you buy the spacers online? Might just bite the bullet on some??
- nfbr
Drop me a message if you're looking for some good quality ones (i.e. H&R or Eibach) and I'll look after you on price as much as I can
- Ed Doe
Have you had a chance to drive the car more since the mid-box removal? Any more info would be much appreciated!
Also, I don't suppose you took any other photos of the exhaust rear-ward of the mid-box, and just before the back-box? I'm thinking of a certain exhaust modification myself, but want to do a bit more research before taking the plunge!!
Finally, can you confirm the diameter of the exhaust pipes? Is each one 2"? Cheers
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, H&S, RTD, 4.1FD
Silver Grey '06 3.0si Coupe - SOLD
