Diagnostic Cable and Software for BMWs 07/2000 - 02/2007
K-Line Diagnostic Cable For vehicles manufactured 07/2000 - 02/2007 from Cable Shack their price: £28.99.
If your car was built between 07/2000 and 02/2007, this cable is all you require. This cable uses the 16 pin OBD port found inside drivers footwell on A post.
What Can You Do With the Cable?
The following is a small selection of what is possible
• Error code reading and resetting - individually or complete car
• Service light reset – SII & CBS service intervals
• Read and reset airbag / EML faults
• Diagnostics – individual modules or complete car
• Resetting adaptations
• Force DPF regeneration
• Checking last regeneration stats
• DDE/DME to CAS alignment
• Resetting electronic steering lock errors
• Programming new injector values after replacement
• Program new ASC/DSC unit to your car
• Activate ABS pump for bleeding
• Power up and check individual modules and there functions
• Test wheel speed sensors
• Show live data
• Vanos testing
• Fuel rail pressures
• Adjust vehicle height (air suspension)
• Vehicle coding/programming & much more
• One click installation
Full details here http://www.cable-shack.co.uk/index.php
£19 including postage
I am upgrading to the D-Can switcched cable which will continue to be used on my E85 and E46 but also enable me to work with Daughter's E91
Norman
• Show live data
• Vanos testing
Norman
Re: Diagnostic Cable and Software for BMWs 07/2000 - 02/2007
Hi there, is this windows based software or does need to set up in VMWARE as I have seen in other packages?
Thanks Phil
Thanks Phil
It does run under the VMware and I have been operating with windows 7. However the installer will resolve all the installation difficulties and there is no need for a 54 page installation manual. Very simple to install and use.Unclepip wrote:Hi there, is this windows based software or does need to set up in VMWARE as I have seen in other packages?
Thanks Phil
Norman
- Terryvision
£15..
Does this included the software?
Of course not much use without!!Terryvision wrote:£15..
Provisionally sold to Unclepip
Drat, just bought a brand new one from the above link for the above RRP, literally clicked buy yesterday! This is a steal for someone!
- sk93
Just to clarify a bit for yah.. it HAS to be in VMWare, as DIS only runs in a flavor of UNIX, and SSS only runs on Windows XP EMBEDDED.Unclepip wrote:Hi there, is this windows based software or does need to set up in VMWARE as I have seen in other packages?
Thanks Phil
You can get INPA, NCSExpert, and those associated EDIABAS tools to run on any version of windows, with various degrees of issues / annoyances, but the others just cannot be run, as they're designed to be an integral part of the big BMW diagnosis machines and not actually installed anywhere other than them.
I'm pretty sure I can guess what flavour of the tools this is, and if I'm right, you'll have no hassle with getting it all working
That's good news then - hopefully it will help me resolve my K bus issues.
