If it were that easy we'd have bought it from the UK. I tried to buy firstly the Z4 retrofit kit and then the X3 kit from a number of UK dealers and made an enquiry to BMW UK: it isn't/wasn't available for order in the UK.
Z4 Heated Seat Wiring loom (Retro - Fit Kit)
- Fishy Dave
Corvette C6
Mazda RX-8 race car
Now sold: Z4M Roadster, the best all round car I have owned.
Mazda RX-8 race car
- -banned-
fitted 6 sets to various models , always ordered vyring from local dealerFishy Dave wrote: ↑Mon Aug 07, 2017 7:57 pmIf it were that easy we'd have bought it from the UK. I tried to buy firstly the Z4 retrofit kit and then the X3 kit from a number of UK dealers and made an enquiry to BMW UK: it isn't/wasn't available for order in the UK.
Z4m coupe
- Fishy Dave
That's good news for others then, which part number are you using?
Corvette C6
Mazda RX-8 race car
Mazda RX-8 race car
Using part no: 6110307620. I tried in the UK and at ECS in the USA where Dave sourced his looms and the response was always the same, 'no longer in production' or 'no longer available'. The same was true when I googled it except for one BMW dealer in Lithuania.It is really good news if there is an alternative available.
Hi Darkangelv2,
Is there any way you could send me the retrofitting instructions for the loom. I just got a z4 3.0 2005 and have all but the loom. I'll try the Lithuania thing but will still need instructions.
I managed to order one of these today from Lithuania. thanks for the heads up.
That's good news. Mine arrived in a few days and were genuine BMW parts. Remember when making your connection to the switch panel that the wiring instructions are for a left hand drive car. Both Marlon's and mine ended up the wrong way round and had to be changed. Not a big problem but hopefully a heads up will save you doing the same thing. Good luck.
- Zulu4
Reviving an old thread... I've trawled to the end of the internet and I've not been able to find anyone selling the retrofit cable (61110307620).
Anyone else had any luck recently?
If it really is no longer available, would it be possible to use a generic heated seat retrofit kit to connect and work with the OEM Z4 heated seat switches ? i.e. do the Z4 switches somehow alter the resistance in the circuit to control heat, or is it all done through the magic of CANBUS ?
2007 3.0si Auto Sport Roadster. Whippy.
Previous:
2003 3.0i SE Roadster. Whippy.
Previous:
- ProfCJJ
I’ve done the same with the same (negative) resultZulu4 wrote: ↑Tue Apr 06, 2021 5:46 pm Reviving an old thread... I've trawled to the end of the internet and I've not been able to find anyone selling the retrofit cable (61110307620).
If you don’t have electric seats though, the heated part is controlled through PWM from one of the body control units (I forget which one) which makes me think I could get a generic set work as they too tend to work with PWM to regulate the different settings.
- Zulu4
Please keep us updated if you do manage it Christopher.ProfCJJ wrote: ↑Wed Apr 07, 2021 1:03 amI’ve done the same with the same (negative) resultZulu4 wrote: ↑Tue Apr 06, 2021 5:46 pm Reviving an old thread... I've trawled to the end of the internet and I've not been able to find anyone selling the retrofit cable (61110307620).
I wonder if a generic kit with a three-position heat switch, you could just cut this off and wire up to the OEM switch ?
(I have the 2007 E85 model with electric memory seats)
Previous:
Previous:
Yes please keep me updated I’m trying to get a loom but it’s a bit of a minefield to know exactly what is required think I may call bmw but they are pretty useless wen it comes to things like this
I dont know about the e85/6 but on the e89 I made the cable, its not that hard, which uses the PWM from the JBBF module (which needs coding). its in here if that helps. I assume there's some similarities
viewtopic.php?p=1363305
- Zulu4
Interesting read. Thanks.clarker63 wrote: ↑Wed Apr 07, 2021 3:15 pm I dont know about the e85/6 but on the e89 I made the cable, its not that hard, which uses the PWM from the JBBF module (which needs coding). its in here if that helps. I assume there's some similarities
Where did you get the correct size connectors from to make up the cables so that they fit into the existing plugs ?
Previous:
Previous:
from bmw. I think I posted the part numbers in the thread.. just checked and they are below the first picture I posted.
- Zulu4
Ah, thanks missed that bit.
If I understand you correctly, the variable heat to the mats is controlled by a pulse width modulation of current (via 12v voltage). I'm guessing that the heated seat switch in the car is just providing its position in binary form to a processor, which then switches a small power transistor on and off for the PWM. Am I along the right tracks ?
So, if I could get a generic kit with a 3 position switch (similar to that fitted in an E85), I might be able to fit the kit to the BMW OEM switch instead. Any thoughts on this idea?
Previous:
Previous:
