I have for sale E85/86 M Sport front & rear anti roll bars. Front is 25mm diameter and has poly bushes fitted. The rear is 19mm. Both are used and have some surface rust.
£20 collected from Salisbury or Aldershot
FS E85/86 M Sport F&R Anti-Roll Bars
- IMG_0426[1].JPG (302.92 KiB) Viewed 551 times
Are they an upgrade from standard arbs for a 3.0?
How would it be to post them by royal mail as interested
Just did some research, thanks for the postage cost.
They are the standard ARB'S, so not of interest sorry.
As stated they are M Sport Anti-roll bars. If you have a 3.0 then you will have M Sport suspension as standard.
If you have a 2.5, 2.2, 2.0 then you have (as standard) non M Sport suspension which has anti-roll bars of 24mm front and 18mm rear, so this is an upgrade.
Sorry just spotted that, yes have 3.0si so standard
thanks again
thanks again
£20 is worth it just for the bushings!
Good point - I forgot that I paid £30 for the bushes - maybe I should sell these separately
