I have (I think) Pm'd you my address thanks again let me know if you didn't get my pm as I can't tell if it went through or not
Matt
I honestly don't know?
Ah. The reason I have these going begging is because my 2.2 box was unfortunately replaced with a 3.0 once hence them not fitting! Do you want to measure your pipes first before I send them?
I see - let them go to someone else then.greg81 wrote: ↑Thu Aug 17, 2017 9:33 amAh. The reason I have these going begging is because my 2.2 box was unfortunately replaced with a 3.0 once hence them not fitting! Do you want to measure your pipes first before I send them?
They will only fit a 60mm oval diameter pipe and I believe all the 3.0 box pipes are 70mm. Afraid
Sorry it didn't work outMarlon wrote: ↑Thu Aug 17, 2017 11:29 amI see - let them go to someone else then.greg81 wrote: ↑Thu Aug 17, 2017 9:33 amAh. The reason I have these going begging is because my 2.2 box was unfortunately replaced with a 3.0 once hence them not fitting! Do you want to measure your pipes first before I send them?
Thanks for letting me know
