Loud tappet like noises from Engine....
"M" Specific discussion
Z4M-2006
Post by Z4M-2006 » Thu Oct 19, 2017 2:45 am
john-e89 wrote: Wed Oct 18, 2017 9:18 pm
Z4M-2006 wrote: Wed Oct 18, 2017 8:41 pm So have they dropped all the big end shells out and checked the crank ???
Any pics of the spun shell ?
I have rebuilt numerous S54's over the years that have spun the bearing and the crank is ALWAYS marked.. Especially one that is knocked that hard...
Have they removed the cam cover too ?
They’ll likely to have shafted the con rods as well won’t they Gaz?
Sometimes it can do the rod too..
In my experience though it always marks the crank, sometimes not fatally and can be dressed back if customer doesn't want to spend ..
That said , I'm no specialist in the S54, just repaired them within my line of work..
But at the very least I would be checking for journal ovality... it's rare that with a prolonged knock that bad that you get away with it..
I had very good money that it was a top end fault on this car going off the video.. the noise frequency seemed way to fast for bottom end...
I have been wrong before though and I'm sure I will be wrong again
T1berious
Post by T1berious » Thu Oct 19, 2017 8:28 am
Update:
They had the cam covers off and I asked them to check the valve clearances while they were at it.
As I understand it (as stated by others) the oil pump was replaced rather than risk it causing another issue, totally got my vote.
Yes indeed, it was bottom end. I believe the crank was not damaged enough to warrant replacement but as someone who know next to nothing about the inner workings of the S54 Engine I'll have to trust the guy who's working on it :)
(Plus wouldn't they want to replace the crank if it was damaged?)
Plus I'm no where near the Garage so again I can't really pop in and want to see damaged parts and setup a web cam of the work being done (wouldn't that be cool?)
But I will ask about the crank today.
Cheers for all the input guys, the good news is (as I understand it) after this work she'll be good for another 100k! SWMBO is still wanting put the nails in though.....
T1b
Current
718 Cayman GTS 4.0, Kia EV6 GT line S
F87 M2C ,F82 440i, E85 Z4MR, E92 330i All Gone!
GuidoK
Post by GuidoK » Thu Oct 19, 2017 8:56 am
Z4M-2006 wrote: Thu Oct 19, 2017 2:45 am
the size tolerance for the crank is quite small. about 0,015mm (0,6 thou ")
I thought it was rather slow for the bottom end (and quite fast for the head).
T1berious
Post by T1berious » Mon Oct 23, 2017 3:30 pm
Well, to the guys who said it wasn't bottom end...
You were right!
Big ends replaced and noise remains. Engine now going to be removed and stripped.
Ouch!
Current
mr wilks
Post by mr wilks » Mon Oct 23, 2017 3:34 pm
T1berious wrote: Mon Oct 23, 2017 3:30 pm Well, to the guys who said it wasn't bottom end...
You were right!
Ouch!
Ouch indeed :cry: at least it will be all fresh when eventually gets diagnosed , almost kinda worrying the "specialist" is playing trial + error though :cry:
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
Boris
Post by Boris » Mon Oct 23, 2017 4:09 pm
I didn't want to argue with "the specialists" but there was no way that was bottom end I'm afraid. :(
Buckz
Post by Buckz » Mon Oct 23, 2017 4:14 pm
and now the bill grows bigger because of extra work, these specialist imo do as much guess work as a forum does.
MrPT
Post by MrPT » Mon Oct 23, 2017 4:14 pm
You were right!
Ouch!
Heard very little in the way of useful diagnostic info from this garage so far. Before they remove the engine, you need to hear, explicitly:
- Bottom end bearings inspected - shells worn but not spun. Bottom end crank, rods etc undamaged. Shells replaced
(at this point you are still OK, economically, as bearing shell proactive maintenance is a good move and you have an invoice plus bill of materials that looks sensible)
- Top end inspected. Valve clearances within tolerance and/or adjusted back into spec. No damage to valve train, springs or seats, or excessive wear of cam followers or lobes
Even after all that you'd still want them take another look at ancillaries, Vanos etc before yanking out the engine.
Don't let them spend your money based on a hunch. That's our job. :D
2006 Z4 2.5si: gone
Ducklakeview
Post by Ducklakeview » Mon Oct 23, 2017 5:46 pm
Ducklakeview wrote: Fri Oct 13, 2017 2:49 pm Definitely valvetrain related, sounds like just the one cam/follower knocking. I'd not be running that until it's been apart for inspection. At this point the cam/follower "may" be salvageable. Keep running it, and it won't..
Mike
Erm...
Sorry but I called top end on day one!
I really don't know how these "specialists" can call themselves so, if they can't get basic diagnosis right..
I feel for you OP..
And WTF do they want to pull the motor for?
Mike
Z4M-2006
Post by Z4M-2006 » Mon Oct 23, 2017 6:01 pm
Op....
Did they actually show you any of the shell bearings,or that there was anything actually wrong with the bottom end..?
Whats the situation with the misdiagnosis,do you have to pay ?
When you posted the video,it sounded just like cam follower wear to me as i said early on,but its so hard to diagnose a noise on the net.
Again its all speculation, but when building an S54 there are certain criteria that must be checked and checked again. Tolerances are fine and if build processes are not adhered to then you get problems down the line.
So........... Its either top end,which will be very easy to see,and if they have done the valve clearances as instructed then they should have seen it..
Or........ The crank is oval and they havent measured to check
Or......They havent used Plastique to size the bearings and fitted the wrong size
Or...... Used a damaged rod in the build,and its immediately damaged the bearing shell.
Good luck with it,i feel for you..
You aint the first or the last thats encountered these problems with the S54....
Ducklakeview
Post by Ducklakeview » Mon Oct 23, 2017 6:09 pm
Z4M-2006 wrote: Mon Oct 23, 2017 6:01 pm ..
As above, these are not only common sense when building ANY engine, they are "basic skills" in the field,
As such, if I was the OP I would be taking it elsewhere..
Mike
Beedub
Post by Beedub » Mon Oct 23, 2017 6:10 pm
this is insane.
Ewazix
Post by Ewazix » Mon Oct 23, 2017 6:47 pm
Farcical, tough reading when someone is being mugged-off like this :cry:
2018 Cooper S Countryman
Fiesta Ecoboost
pHilli0
Post by pHilli0 » Mon Oct 23, 2017 7:06 pm
You were right!
Ouch!
OMFG!!! The overwhelming view from your vid was top end. And the bottom end has been worked on and the noise is still there. I am pretty speechless. You must get evidence that the bottom end had failed, something otherwise are you being taken for a ride by someone guessing?
Is this where there was wear to the bearing shells, as they usually is, and they put the diagnosis on that?
TBH when I first had my engine diagnosed I spent the 1 hour labour charge at a MAIN F****ING DEALER who told me I just needed the clearances done, and never spotted the cams and followers were in a state and ticking. These issues seem to sometimes be missed, but this situation seems either a tragic mess or something else going on.
2006 Z4 ///M Coupe || Schrick CSL Cams | Eventuri | Brembo 6/4 & Pagid RS-29s | KW V3s | H&R ABRs | Stromung | ARC-8s | Corbeau Revolution | OEM Strut | ZHP | Stubby | CDV | RTAB | Evolve Map ||
http://www.phillynchracing.com/index.php/blog/
jimmybell
Post by jimmybell » Mon Oct 23, 2017 7:31 pm
have they checked the follower fingers for wear?
V12 Vantage S - Hammerhead Silver, Manual, Lightweight Wheels, Exterior Carbon++, Carbon Buckets, AMR Performance Pack.
M135i LCI - ZF8, White, HK Audio, Adaptive
GONE Z4 M Coupe, Imola, CSLs
GONE C63 AMG, Black, Performance Pack+, LSD, HK
