Loud tappet like noises from Engine....
"M" Specific discussion
pHilli0
Post by pHilli0 » Fri Oct 13, 2017 7:21 pm
T1berious wrote: Fri Oct 13, 2017 2:34 pm Right, the last time it was in was last year and it had an Inspection II 2015 so it's due one. I have done a video and currently looking at decent local indies as I've seen horror stories from main dealers with costs north of 4k.....
Last oil change would be last year. It has always gone to a main dealer.
It is however the dreaded marbles in a can sound while idle and rising in frequency with revs.
I'll pop the video into this once I work out how to upload it!
https://youtu.be/Re2J4Di1QDs
Cheers T1b
Oh No!
Here is my vid when my engine decided to ruin my day:
https://www.youtube.com/watch?v=_AMXkqcYxGY
I needed new cams / follows and a top end rebuild. Start looking at Schrick cams.. sorry bud, this is gonna cost ya a fare whack
2006 Z4 ///M Coupe || Schrick CSL Cams | Eventuri | Brembo 6/4 & Pagid RS-29s | KW V3s | H&R ABRs | Stromung | ARC-8s | Corbeau Revolution | OEM Strut | ZHP | Stubby | CDV | RTAB | Evolve Map ||
http://www.phillynchracing.com/index.php/blog/
ph001
Post by ph001 » Fri Oct 13, 2017 8:09 pm
Hmmm...similar but not identical. Yours seemed to only be apparent when revving whereas the OP's was more at idle. We are all speculating a bit still I think. Needs proper diagnoses.
Z4M-2006
Post by Z4M-2006 » Sat Oct 14, 2017 12:22 am
It's a forum
All we can do is speculate..
T1berious
Post by T1berious » Sat Oct 14, 2017 7:53 am
Car safely back on drive after being transported back home via AA. Will be being recovered by garage on Monday.
But I'm fully prepared for a >1.2k - 2k spend.
the video was at cold idle.
car was gingerly started to get on the drive and that's it.
She'll be back, bright as a button and in rude health!
I'll keep you posted.
T1b
Current
718 Cayman GTS 4.0, Kia EV6 GT line S
F87 M2C ,F82 440i, E85 Z4MR, E92 330i All Gone!
mmm-five
Post by mmm-five » Sat Oct 14, 2017 10:08 am
TomK wrote: Fri Oct 13, 2017 6:16 pm Bearing in mind cold start idle is around 1150-1200 and the noise heard you'd have to say it's the cams/followers.
How 'cold' is cold start' for an unmodified M?
Mine cold idled this morning at about 850-900rpm (i.e. after being sat outside for 36 hours)...for the 10 seconds or so that it was immobile of course :P
But I’d agree with the majority here, and not drive it until it’s checked/fixed, as a £1k bill is much more preferable than having to replace the engine or fully strip/rebuild it.
Trigger’s Z4MC
Some bits now over 163,000 miles, some less than 1,000 miles.
Individual Ruby Black, Individual extended champagne leather, plus many options
TomK
Post by TomK » Sat Oct 14, 2017 12:25 pm
mmm-five wrote: Sat Oct 14, 2017 10:08 am
Oh I'm not sure for standard, mine definitely cold starts around 1.2K for a minute or so, maybe that's part of my map but I thought the car did that beforehand, it's been a while though.
BMWZ4MC
Post by BMWZ4MC » Sat Oct 14, 2017 12:30 pm
I'm in the followers / cams camp. The good news is that the primary failure seems to be the case hardening on the followers, so catching it early and not driving further avoids damage to the cams. If that is the cause, Schrick sell OEM followers to which they apply an additional hardening process. They aren't terribly expensive although I would replace them all. If you need news cams, they are pretty costly and the labour required increases significantly due to the limited access in the Z4M (cf the E46 M3). The job can be done without dismantling the entire front of the car but only by someone who knows what they're doing.
Where are you based? Phil at CPC in Amersham has done this job on several forum cars and many M3s.
S2000 GT - gone
GuidoK
Post by GuidoK » Sat Oct 14, 2017 12:50 pm
Z4M-2006 wrote: Sat Oct 14, 2017 12:22 am It's a forum
Exactly. It can still be some blowby at a loose sparkplug or manifold.
Diagnose requires a stethoscope, not a youtube video :lol:
T1berious
Post by T1berious » Sat Oct 14, 2017 2:47 pm
We'll see,
It was cold for a few hours. mines is stock but I get the feeling that while the work is being done I'll be looking at getting some "preventative" maintenance done.
The car has to last till the mortgage is finished (6 years).
It's a toy car so it will be used for pretty low mileages. in 8 years it's done 40K. Was at the Tesla showroom today. 100D is screaming my name.
Any suggestions on what I should get done (engine wise) at the same time greatly appreciated
Current
BMWZ4MC
Post by BMWZ4MC » Sat Oct 14, 2017 3:20 pm
At 91k, changing the bearing shells would be a good idea. I changed mine at 50k and they were pristine, but others have changed them sub-100k and found significant scoring. If they fail, the bill is seriously big bucks. Changing them should be in the high hundreds for parts and labour.
S2000 GT - gone
Z4M-2006
Post by Z4M-2006 » Sat Oct 14, 2017 4:22 pm
See what your noise is first....
I would be getting the bearing shells done and a set of shrick cams and followers..
Good for another 100k then..
dannytheduck1985
Post by dannytheduck1985 » Sat Oct 14, 2017 4:25 pm
Mine had just been diagnosed as big end bearing
84’ E28 Alpina B9
83’ VW B2 Passat CL
90’ Mercedes 300E-24
90’ Vauxhall Carlton GSI 3000 24V manual
85’ Opel Ascona Cabriolet
T1berious
Post by T1berious » Tue Oct 17, 2017 12:00 pm
Well,
It looks like Big end bearing \ bearing shells \ cams and followers at the moment. Garage is going to assess today but initial thoughts were it's from under the engine rather than top.
I'll keep you posted. (Mrs is already putting the nail in and suggesting a trip to the Porsche dealer...)
Sigh
Current
ph001
Post by ph001 » Tue Oct 17, 2017 12:25 pm
It's not that likely to be both shells AND cams causing your noise but as above you might want to get both done anyway while it's in bits.
T1berious
Post by T1berious » Tue Oct 17, 2017 1:12 pm
It feels a bit like a few days after a first date.
Do you call? Do you wait? You don't want to seem to keen but if its "lets just be mates" you'd rather know sooner right? I'll wait as I'm hoping to hear "All fixed! that will be £3.50" but I don't think that will be case...
Sigh
Current
