Winter Project
Winter Project
Another update.
I've changed the passenger side RTAB, and fitted the limiters to the cage.
Old bush looked OK but was very soft.
Limiters fitted to the cage
Cage sitting over new Meyle HD bush.
Stopped for today as BMW don't have all the new bolts in that I ordered. They should have them in tomorrow, so I'll be able to put it all back together once I've picked them up.
As an aside, People make a big deal over changing these bushes, but they are an absolute piece of piss. There is no need to go powerflex just to ease fitting, I had the bush out and new one in within 10 mins, it really is that easy.
///M|Silver Grey|Black Leather|BT|Nav|DSP|Heated Seats|PDC|Stubby|Turner Limiters|Turner Rear Top Mounts|Bilstein B12|Powerflex ARB Bushes|Powerflex Lollipops|M-Track|
SOLD
SOLD
- TomK
Winter Project
I thought it was supposed to be a bit of a pain, good to know.VRSteve wrote:Another update.
How are you going about setting the preload on them? Do you have the BMW tool or just eyeballing it?
Winter Project
I have a length of metal bar, I'm going to weld a nut to the end of it and put a long bolt through it, it won't be perfect but it will be close enough.TomK wrote:I thought it was supposed to be a bit of a pain, good to know.VRSteve wrote:Another update.
SOLD
SOLD
- TomK
Winter Project
Sure, close enough should be fine. The bmw tool wouldn't be quite right for me anyway as I'm not at standard ride height.
Winter Project
Same for me.TomK wrote:Sure, close enough should be fine. The bmw tool wouldn't be quite right for me anyway as I'm not at standard ride height.
Although I've done it in 2 stages essentially I have the Bilstein B12 kit fitted so it would be slightly out if I used the BMW tool anyway.
If I wreck a pair of bushes I know I can change them in half an hour so it's not the end of the world of I get them slightly out!
SOLD
SOLD
Winter Project
I'm about to do the exact same job. What bush pressing tool did you use?
Current: 06 E85 M Silbergrau
Previous: E85 3.0si Silbergrau, 03 E85 2.5i Maldives Blue.
Mods: Gaptech OTH+R, Dension Gateway 300 with USB, CDV-, clear side indicators, euro tails, stubby, MFSW retrofit, OEM Bluetooth/VR
Winter Project
Whats the technique to preload the bush, I have tried to look in to this but could not understand the process to go through
07 Z4MC standard spec
- Paulr
Winter Project
What is an RTAB?
If you try and take a cat apart the first thing you have is a non working cat.
Winter Project
http://www.ebay.co.uk/itm/BMW-3-Series- ... Cbuodqs4NgMangozac wrote:I'm about to do the exact same job. What bush pressing tool did you use?
Small tip, use a jubilee clip to compress the new bush just to get it started, once it starts to seat you can take it off, assuming you are going to stick with OEM style bushes.
Put plenty of copper grease on the thread of the bush tool
Also, mark the location of the cage and bolts before you undo it, otherwise you'll get in a right mess putting it back together!!
SOLD
SOLD
Winter Project
The idea is that the bush shouldn't be under tension when the car is sitting on its wheels.Viren wrote:Whats the technique to preload the bush, I have tried to look in to this but could not understand the process to go through
The BMW tool bolts to the RTAB cage and then holds the cage 8mm above the centre line of the axle, while the cage is held in place you bolt the cage to the RTAB, so maintaining the position.
I bolted a flat bar to the cage and just rested it level with the top of the hub nut. Its less than 8mm, but I'm running at a non standard ride height, so will be close enough.
SOLD
SOLD
Winter Project
Rear trailing arm bush.Paulr wrote:What is an RTAB?
SOLD
SOLD
- Paulr
Winter Project
Ahh, thanks.VRSteve wrote:Rear trailing arm bush.Paulr wrote:What is an RTAB?
Winter Project
SO.
Went to BMW to get all the nuts and bolts I needed.
Still missing the new rear bump stops.
Put the passenger side back together, did the drivers side, only to realise I'd not got the passenger side bush quite where it should be, (Inside edge should be flush, outside edge should stand proud) and I'd got the pre-load totally wrong!!
Did the drivers side correctly, and corrected my mistakes on the passenger side.
Just need to put all the wiring back in its clips and reattach the guards and the RTABs are done.
Depending on how many things the other half has planned for me to do tomorrow I'll try and finish off the RTABs and then drop the rear shocks. Could to the ARB bushes too I guess.
SOLD
SOLD
Winter Project
Do you leave the hub hanging or have it rested/raised on car jackVRSteve wrote:The idea is that the bush shouldn't be under tension when the car is sitting on its wheels.Viren wrote:Whats the technique to preload the bush, I have tried to look in to this but could not understand the process to go through
