Millers oil
"M" Specific discussion
Das882
Millers oil
Post by Das882 » Sat Feb 11, 2017 8:59 pm
I'm intending getting the Millers oil analysis done one my Z4MC, whilst looking on their website I checked out what the recommended engine oil was.....CFS 10W60. Does anyone use or have used this oil in their M ?? I have used Millers in both of my previous cars, an Elise and Cosworth engined TVR without issue.
Dave.
2006 Monaco Blue Z4MC
WLH
Millers oil
Post by WLH » Sat Feb 11, 2017 9:13 pm
10W60 with either the BMW label or the Shell 10W60 is all I have ever used.
2007 ///M Roadster - My Zed's - Member ZSCCA - ///M Registry - My Videos
AlfaScozzesi
Millers oil
Post by AlfaScozzesi » Sat Feb 11, 2017 9:29 pm
Mr Wilks is a big advocate of Millers and he has used it in his previous M roadster.
I have just stayed with Castrol now Titanium 10W60 while BMW have switched allegiance to Shell.
Just had an inspection 2 done at BMW and supplied my own oil to make sure this was kept up.
Millers is a good quality oil so there will be no issue.
buzyg
Millers oil
Post by buzyg » Sat Feb 11, 2017 10:29 pm
I still have a few ltrs of titaniam from my last oil change. As said BMW have moved over to Shell. Can't see any reason why Millers 10W60 would not be perfectly fine oil for an ///M :thumbsup:
mr wilks
Millers oil
Post by mr wilks » Sun Feb 12, 2017 12:39 am
Get it in the car Das , just my own thoughts but the S54 has a penchant for trouble connected with heat / cold starts & for me there is no better fluid than Millers to cope with both those factors
My current ZM will be in shortly for INS2 & its Millers all the way for me 8) engine , box & diff :thumbsup:
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
Das882
Millers oil
Post by Das882 » Sun Feb 12, 2017 7:20 am
Millers it is then !! Thanks,
Dave.
Babw
Millers oil
Post by Babw » Sun Feb 12, 2017 12:01 pm
I've been using Millers CFS NT since my last inspection 2 a year ago and it's noticeably smoother on a cold start.
The newer Ester based oils are a few steps above the older synthetics, Ester based oils have a better HTHS viscosity for the same KV100 (kinematic viscosity at 100ºC). It's good for cold start and high temperature track work. I've been looking to do a high power build one of my other cars and Ester based oils have come out on top with quite a few tuners.
GrantIII
Millers oil
Post by GrantIII » Sun Feb 12, 2017 12:39 pm
Millers in Engine Gearbox & Diff in mine !!!
Low miles .... Imola M, with cruise & no roof !
mr wilks
Millers oil
Post by mr wilks » Sun Feb 12, 2017 1:17 pm
Not just good for S54s the Millers range also has suitable oils for N52 N54
Also worth mentioning on this thread specifically for the ///M owners who have one (or both :P ) eye on cam wear or bearing shell wear & missed the link for oil analysis on previous thread http://www.millersoils.co.uk/automotive/millercare.asp
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Das882
Millers oil
Post by Das882 » Wed Mar 08, 2017 5:28 pm
In case any other Miller fans are wondering about the new Black 10W 60 containers..... I contacted Chris at Opie oils who said "it is the same oil with some extra Nanodrive additive making it better than before and ideal for your Z4M"
Opie oils price is £45.95 which is the best price I have seen so far.
Dave.
Das882
Millers oil
Post by Das882 » Thu Mar 09, 2017 12:04 pm
Has anyone tried this suggestion from Opie oils when asking about gearbox oil for my Z4MC??
" In that case the Millers TRX 75w-80 is the best option for the gearbox, although if it is stiff when cold (as is common with BMWs of that age), use a 50/50 mix of the TRX and ATF DM."
There's nothing unusual about using ATF in a manual box as my Cossie T5 box used it , but I've never heard of mixing 2 different oils??
Dave.
Anakin
Millers oil
Post by Anakin » Fri Mar 10, 2017 3:56 pm
I have Millers Race oil in my TT RS. not got as far as having to service the Z4M yet. Dont think they use the same stuff though :(
Monaco Blue Z4M Roadster & Solar Orange TT RS
Viren
Millers oil
Post by Viren » Fri Mar 10, 2017 4:15 pm
Anakin wrote:I have Millers Race oil in my TT RS. not got as far as having to service the Z4M yet. Dont think they use the same stuff though :(
Bit of topic but how does your ttrs compare to the z4m?
07 Z4MC standard spec
Anakin
Millers oil
Post by Anakin » Fri Mar 10, 2017 5:15 pm
Z4M is stock, TT RS has a remap, decats, MPSS H&R springs (Mag Ride). 414bhp and 429ft/lbs and Haldex 4wd it grips and goes makes a awesome noise. I run winter tyres for the colder months. Its a very quick and easy to drive daily.
The Z4M roadster is a more "fun" car to drive on a nice day, much rather be in the TT on a cold wet day. Can't wait for some decent sunshine so I can take my wooly hat off :P
