Fitting Cruise to the M - links?
Have bought the stalk and loom (via Sopers of Lincoln - see separate post) - does anyone have a link to a post for fitment to the M?
Is it any different to other types of facelift Zeds?
Scooba Steve is your man Paul
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
I'm not sure anyone has done a DIY but is possible as I think Peter Van Der Deer have done one or two for members.
I have looked at the wiring diagrams and think I know where the connection needs to be made, just need someone to try it. No idea if it would need coding, I don't think it should but worst case would be to pay for someone to do it.
- Swiftly
Hope this link helps Paul, there appears to be loads of info, especially about fitting to an ///M half way down the page viewtopic.php?t=14699&start=210paulgs1000 wrote: ↑Fri May 05, 2017 11:29 am Have bought the stalk and loom (via Sopers of Lincoln - see separate post) - does anyone have a link to a post for fitment to the M?
- srhutch
- Moderator
Hi Paul, as in my post the other day the ///M is different to all other models. It might just be where it plugs into the ECU. I can tell you where this is later when I get home. Somebody has said that it does require coding, but I'm not so sure.paulgs1000 wrote: ↑Fri May 05, 2017 11:29 am Have bought the stalk and loom (via Sopers of Lincoln - see separate post) - does anyone have a link to a post for fitment to the M?
So it could be as easy as an other face lift zed. Remind me later if I haven't contacted you with the details.
Wiring for S54 below. It ends in the same place as the N52 but isn't where I would be connecting it for the N52.
I'd have to look on WDS to see where the module is on the M.
- MS70 S54 Cruise.PNG (63.21 KiB) Viewed 983 times
- srhutch
- Moderator
I believe it is Pin 4 on plug 60002 though, but this is in no way confirmed yet. This appears to be confirmed by Scooba_steves post, which is good news and confirmation I needed.
I might see if I can do mine on Sunday now.
- Beedub
has this finally been cracked ????
come back to us and let us now.
- pvr
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- srhutch
- Moderator
- srhutch
- Moderator
- Beedub
yessssssssssssssssss!!!!
please document !!
please document !!
As I said many moons ago, fit it and worst case it needs coding, still save plenty on labour and better than the parts sitting in the box Can't see why it would need coding though but may well be wrong.
I'd be interested to know if the connection between X6021 and X60002 exists, if pin 4 at X60002 is occupied then it must but will need removing as I can't see the X6021 connection being made with the retro loom.
I've also wondered why the N52 cruise goes through the Integrated Supply Module when it seems to just be a pass through connection.
Thanks all - hope to get to the way forward through this post - magic
