Inspection 1
"M" Specific discussion
mmm-five
Inspection 1
Post by mmm-five » Wed Jul 19, 2017 4:00 pm
Beemingallover wrote: Wed Jul 19, 2017 3:36 pm Dealer now says Inspection 1 does not do valves, check or otherwise!! That's Inspection 2 only.
The dealer is wrong. Show them your service schedule in your service booklet. The can't arbitrarily change what's included for profit's sake.
It may not need doing for an inspection 1 of new M models, but then it should only be a few £££ more than an oil service then.
They can't continue to charge full price when they're only doing half of the work :thumbsdown:
This also goes to show the difference between a 'fully stamped by BMW' service history and a 'full & correct service history' - buyer beware :fuelfire:
Trigger’s Z4MC
Some bits now over 163,000 miles, some less than 1,000 miles.
Individual Ruby Black, Individual extended champagne leather, plus many options
D4dawg
Inspection 1
Post by D4dawg » Wed Jul 19, 2017 5:49 pm
See :D
Different BMW dealers are obviously saying and doing different things
Thank you kindly !!!
Thank you fishy for the polite reply :D
Pastry
Inspection 1
Post by Pastry » Wed Jul 19, 2017 5:57 pm
D4dawg wrote: Wed Jul 19, 2017 12:25 am The rest is checks
Sorry at £619+ at bmw I'm not paying £300 for someone to visually check my car
Indeed, it only took Bryan and I 5 mins to spot your speedo was full of dust and your door cards were dirty :poke:
991 Carrera 2S
Now gone:
2010 Z4 23i Msport and a 3.0i
Smartbear
Inspection 1
Post by Smartbear » Wed Jul 19, 2017 6:27 pm
Pastry wrote: Wed Jul 19, 2017 5:57 pm
Did you charge less than the quoted £300 though? :D
e85 3.0si sold
D4dawg
Inspection 1
Post by D4dawg » Wed Jul 19, 2017 9:55 pm
Exactly!
See you boys saved me £300!;)
D4dawg
Inspection 1
Post by D4dawg » Wed Jul 19, 2017 9:57 pm
Smartbear wrote: Wed Jul 19, 2017 6:27 pm
Haha that was free, it was the taking pee of my marked buttons on the wheel that I was forced to buy a sexy set of refurbed ones ;)
No regrets as makes wheel.look as new
Beemingallover
Inspection 1
Post by Beemingallover » Thu Jul 20, 2017 8:49 am
How critical then is it to check valve clearances, in my case they were last done at 48k on inspec 2, fully documented by dealer. The car has now done 69k. How frequently should they be checked?
:driving: Z4MR 2006 Interlargos Blue/Sepang Bronze SUMMER
E92 M3 coupe manual 2009 Silverstone Blue WINTER
M635Csi 1986 manual Lachs silver. GONE.
Bing
Inspection 1
Post by Bing » Thu Jul 20, 2017 9:13 am
Beemingallover wrote: Thu Jul 20, 2017 8:49 am How critical then is it to check valve clearances, in my case they were last done at 48k on inspec 2, fully documented by dealer. The car has now done 69k. How frequently should they be checked?
If the clearances aren't right your engine can break - is my complete layman understanding. It appears that if the clearances are too high the lifters/valves can wear out, and if they are too tight the valves can end up burnt... But that's just some random googling that's given me that explanation - I'm sure someone with proper tech knowledge can correct me. Anyway, the service schedule says it should be done and received wisdom on here is it should be done, so I would make sure it's done. The schedule says every Insp 1 & 2, so that would work out at roughly every 24-30k miles with an oil service in the middle, depending on how the car is driven.
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin 8)
99ron
Inspection 1
Post by 99ron » Thu Jul 20, 2017 7:03 pm
This is why I no longer use main dealers for servicing. Half of them don't have a clue about the S54 engine anymore. Good specialist is the way forward. I got a valve clearance report on inspection 1 and didn't have to ask for it.
Z4MR E85 for sunny day Hooning. 8)
Now with added joy of Gruppe M.
Mangozac
Inspection 1
Post by Mangozac » Thu Jul 20, 2017 11:14 pm
Bing wrote: Thu Jul 20, 2017 9:13 am If the clearances aren't right your engine can break - is my complete layman understanding. It appears that if the clearances are too high the lifters/valves can wear out, and if they are too tight the valves can end up burnt... But that's just some random googling that's given me that explanation - I'm sure someone with proper tech knowledge can correct me. Anyway, the service schedule says it should be done and received wisdom on here is it should be done, so I would make sure it's done. The schedule says every Insp 1 & 2, so that would work out at roughly every 24-30k miles with an oil service in the middle, depending on how the car is driven.
The clearances have to be WAY out for any of those things to happen, and wear to that degree can only happen if something is very wrong with the engine. The valve adjustments are usually just ensuring that the engine is operating as efficiently as possible in order to provide the power/performance expected. I would suggest that an owner who never pushes his S54 hard could get away with only having the clearances done at an inspection 2 (or longer).
Current: 06 E85 M Silbergrau
Previous: E85 3.0si Silbergrau, 03 E85 2.5i Maldives Blue.
Mods: Gaptech OTH+R, Dension Gateway 300 with USB, CDV-, clear side indicators, euro tails, stubby, MFSW retrofit, OEM Bluetooth/VR
Bing
Inspection 1
Post by Bing » Fri Jul 21, 2017 5:37 am
Thanks for clarifying - as I said, I have a layman / Google understanding of the reasons for doing it, and tbh just want to follow the service book. Should provide some comfort to most.
That said, mine was one owner / 40k ish miles not abused when I had an insp2 done and it needed 14 shims. Probably because they weren't checked (by BMW !) at its first insp1. So I guess if it hadn't been done then the clearances *could* have started to get to the point where they did damage.
indeep75
Inspection 1
Post by indeep75 » Fri Jul 21, 2017 12:10 pm
Just booked mine in for it's inspection 1 at my local indy, CPC Performance in Amersham. Before I even asked they said it includes the valve clearance check with full print out of adjustments. £395 in total, quite happy with that!
Z4M Coupe Silver-Grey / Light Sepang Leather Extended / Piano Black
Gone: Z4M Coupe Silver-Grey / Imola Red / CSLs
Gone: Space Grey E89 28i
https://www.instagram.com/indeep75_
TomK
Inspection 1
Post by TomK » Fri Jul 21, 2017 12:34 pm
That's a very good price. I'd check they are not planning on reusing the valve cover gasket amongst other things (should be a new one), as some other indy's (e.g Redish) go down this road to cut prices. Parts for the job make up a fair proportion of £395, and it's not one to be rushed imo.
indeep75
Inspection 1
Post by indeep75 » Fri Jul 21, 2017 12:43 pm
Yep, that's a good point TomK. Fairly confident with CPC though, they have a good rep on here and on other M3 forums. They said it would be a two day job (cold engine for clearance check) without prompting, I've heard of others who neglect this entirely.
D4dawg
Inspection 1
Post by D4dawg » Fri Jul 21, 2017 1:25 pm
indeep75 wrote: Fri Jul 21, 2017 12:43 pm Yep, that's a good point TomK. Fairly confident with CPC though, they have a good rep on here and on other M3 forums. They said it would be a two day job (cold engine for clearance check) without prompting, I've heard of others who neglect this entirely.
Have to see your car first hahah
As not seen it in a while keep my eyes out in beaconsfield
