GreyZed said:I was thinking more of a dedicated tool than a laptop/pc based solution.
Scooba_Steve said:Bcables.com - comes with INPA
jeffers said:Slightly OT here bit does anyone know if I need the K-line or DCAN cable for coding an 2008 E86? The bcables site is a bit ambiguous with nothing specifically for the Zed
RickZ4 said:jeffers said:Slightly OT here bit does anyone know if I need the K-line or DCAN cable for coding an 2008 E86? The bcables site is a bit ambiguous with nothing specifically for the Zed
I bought the silver cable for my which works on an '07 E85. The INPA software seems to be in German, though..
JakeGT said:A C110 ScannerHands down the best imo. No faffing around with laptops and leads and I can't think of another scanner under £40 that does ABS and Airbag.
http://www.ebay.co.uk/itm/BMW-C110-MANUFACTURER-OBDII-FAULT-CODE-ENGINE-ABS-TRANSMISSION-AIRBAG-SCANNER-UK-/201424851513?hash=item2ee5db5239:g:aDwAAOSw34FVCUiC
SeanConnor said:Be aware that if you go with Carly you will need a Carly specific OBD2 reader. With the latest software the generic OBD2 widget will no longer work . :thumbsdown:
DaveZ4richardson said:JakeGT said:A C110 ScannerHands down the best imo. No faffing around with laptops and leads and I can't think of another scanner under £40 that does ABS and Airbag.
I got this scanner, came in very handy to establish which brake pressure sensor was faulty, carry it in the car 24/7 now.![]()
