Brake Caliper Options
6 pot BMW/Performance Brake / Brembo for £1,200 or F series build your own…
https://e89.zpost.com/forums/showthread.php?t=918116&highlight=BBK
Ive also been looking into a big break kit. What do people do with the rears? does the eletronic parking break give you less options? I saw PB breaks have quite the build but havent heard much about them before.
Are you thinking of an upgrade or just OEM type replacement?
need to take a lot of care with the fitment, from memory the 35is has bigger brakes than everything else in the range.
Apart from a company called PB that makes a rear kit there are no known solutions…if you have a US 35i or any other E89 bar a 35is then you can fit the bigger euro spec 35i/35is rear disc n caliper..
Going to be upgrading to apex wheels so I should have room for a bigger kit, Shame theres not more options for rear while keeping the EMF. PB looks good just rather stick to something more established thats not going to break the bank.
F series 4 pot bmw calipers with 370mm discs is the cheap answer
https://e89.zpost.com/forums/showthread.php?t=1096917&page=8
370x30 mm discs[/I] with 4-piston-calipers (for min. 18" wheels):
4-piston-calipers yellow: 34106855475 + ...6
4-piston-calipers red: 34106855477 + ...8
4-piston-calipers orange: 34106855479 + ...80
discs 370x30 mm (perforated): 34106797603
dust cover: 34116792237 + ...8
brake pads: 34116859066
Or
https://www.mlperformance.co.uk/products/genuine-bmw-e81-e87-e90-e92-338x26mm-front-sport-big-brake-kit-inc-123d-130i-325d-328i?variant=41048959418527&currency=GBP&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gbraid=0AAAAAosiaeEYPH4mJmBVWzPkTZIoB-Ra1&gclid=CjwKCAjw9p24BhB_EiwA8ID5Bl5ZpkqVphGbfalzPGZubIQvk_dOHnUMAL9B3tYeaqyi210lHbDfwRoCUY4QAvD_BwE
