Get the wheels off?
Big piece of wood against the inside of the wheel and use a sledge hammer to shift it.
Careful to catch it when it goes though.
I generally do a bit at a time until I know it will be almost lose.
ba3bas said:
Hit it at 3 and 9 o'clock until it loosens.
Not ideal on front wheels as the hubs will try and turn.
Loosen all bolts a couple of turns from being hand tight then move the car a short distance, not just in a straight line, this should do the trick.
and... when replacing them use a smear of copper grease to ensure that they'll always come off easily in the future
All very good answers. I thought mine were 'welded' on. I had to loosen the bolts to hand tight, get it moving and then slam on the brakes (kacked my pants when it eventually 'cracked')
This is how I got the space saver spare wheel off my 320d...(just without the pants-kacking :P ) :thumbsup:
This is how I got the space saver spare wheel off my 320d....just without the pants-kacking :P ) :thumbsup:
It's quite some bang when it eventually breaks free
Does this happens?
Try to remove safely so, that it do not break.
I think the size would be small and fitted tightly due which this happened.
Would on hit the wheel on a properly supported car though, certainly not on a BMW jack and preferably not on a normal jack either. Last thing you want it the jack slipping and going through your floor/sill!
