Voltage monitoring
The charge level of the standard/rechargeable battery in the key fob transmitter when a button is pressed is monitored.
If the voltage drops to a lower limit, the key fob transmitter signals the battery condition to the basic module. The basic module processes that information as follows:
- The command "Lock vehicle" is not executed. All other functions are allowed.
- The low voltage is registered on the basic module
The message is analysed by the diagnostic program for the radio remote control. It is automatically deleted once the voltage level on the key fob transmitter has been OK again 5 times in succession.
If low voltage occurs, the following operations are required:
- On key fob transmitters with standard battery, the battery must be replaced
- On key fob transmitters with rechargeable battery, the battery must be charged for at least 30 minutes in the ignition lock.
A non voltage-dependent memory in the key fob transmitter ensures that the initialisation data is not lost even if the battery is completely discharged.
