Do these come off the same as the e85? Someone has tried to glue the gasket onto mine before I bought it and made a right mess so it needs taken off and done right.
From memory couple of bolts and some plastic push pin retainers underneath.
Black strips it clips on.
Bit scary to pull off.
Good to get off mud collects behind them.
Look side skirts ebay and you will the mount holes.
Yes there’s a screw at the front too to remove and then remove the 6 or so plastic rivets. I used a fork tool to remove this and I guess I did it wrong because almost all were damaged in the process. Don’t be afraid of giving it a good yank and it will come away. Awesome to get all the dirt and crap out and give it a thorough clean and Lanoguard.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
