There are two systems in the UK for E89s..
Earlier pre 2014? E89s use FRFM..run flat monitor…there are are no sensors in the tyres /wheels…there deflation is ca; ulatec by the DSC system detecting the lower pressure wheel is rotating faster than the other 3 wheels..
Later TPMS come in..tyre pressure monitoring system…each tyre / wheel has a valve with built in radio transmitter and pressure sensor…that sens the pressure in each tyre to a box..the RDC..which then flags a message up on the display if a pressure drops below a certain amount…
So earlier system deduces pressure by relative speed of wheels..the latter system by actual,pressure measurement..
Easy to spot as TPMS has metal shanked valves with a nut at the bottom of the valve stem…runflat has rubber valves..hence my question in the first place..
Comprendo?
