I have got round to fitting the carbon tailgate today but the threaded inserts they have used are M6 and the bolt threads are M8 :x
The fittings concerned are numbered 5 , 8 and 10 on real oem tailgate https://www.realoem.com/bmw/enUS/showparts?id=DU52-EUR-02-2008-E86-BMW-Z4_30si&diagId=41_1696
I have sent Geoff Steel an email regarding this but the person concerned is out until tomorrow . I have asked them if there is enough metal on the threaded inserts to tap out to an M8 or could I reduce the threads on the fittings to M6 which may be easier said than done . Before I get a reply from them my question is will either of these methods seriously reduce the security of the fittings especially the hinges as I don`t want them failing when I`m doing the speed limit down the motorway .
The only other way is for them to have the tailgate back and fit the correct size but again that may not be an option as they are probably done during the moulding stage ??
Advice and any other suggestions welcome . Thank you .
