RPI Air ram scoop fitting
- pvr
Got this kit from Race Precision in the US which claims to reduce the fuel consumption by about 2 mpg as well as increased performance due to the ram air effect.
The replacement filter was a simple swap for the old one, so lid off, remove old, replace with new. No pictures taken from that.
First insert the screws in the holes as they are otherwise very difficult to get in:
Old unit in place:
Old unit removed:
Where the old one used to be:
New one in place:
Use a small screwdriver to fix the top screw first as you still have movement to get your hand in. Use the long screw driver for the bottom and side screw:
Unit installed and seen from the side:
Old unit in place:
Old unit removed:
New one in place:
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- ovrkll
- pvr
Re: RPI Air ram scoop fitting
Just did a test run. Bit more growl under load and a bit more responsive, felt and sounded great
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- IMZ4N
With an air scoop like that , do you think there will be an issue with water getting in the air box, or it that taken care of with the scoop?
- pvr
Water runs straight out again. On Bimmerfest there is a 30-odd page thread on this thing where someone has even put a garden hose up it to test.
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- cj10jeeper
Glad you fitted it and did not require the help of CJ engineering services...
Jaguar F-Type 3.0 Supercharged V6 S, Stratus Grey, LSD, Active Exhaust, CF wheels, Performance brakes, Sports seats and mods ongoing
Gone but not forgotten Z4 3.0i SE Roadster ///M front, Red ///M leather seats, Aero sills
- pvr
Took 10 minutes, you could have done that whilst I was on the phone
Having said that, when I took the grill off I noticed that the paint was loose / peeling around the edge of the grill. Just been to the dealer, entire bumper respray now booked in.
Look closely at the picture of the grill removed, and look at the right top. You can see it there.
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- IMZ4N
You guys know how some forums are. You just never know who is telling the truth and who is not. I also know I would get the straight answer here.pvr wrote:Water runs straight out again. On Bimmerfest there is a 30-odd page thread on this thing where someone has even put a garden hose up it to test.
Rumor has it, you can offset any labor charges if you buy a few beers.Glad you fitted it and did not require the help of CJ engineering services...
- pvr
IMZ4N wrote: Rumor has it, you can offset any labor charges if you buy a few beers.
Arggh, is that where I went wrong. I brought wine ...
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- cj10jeeper
Wine is good I just think that sat in the garden eating was easier for both of us on the day....
Strange that the paints pealing off.
this can be fit on 2.5 or not and if yes it will work?
- pvr
Depends on the age of the car (i.e. facelift or not). Have a look at the thread about this on bimmerfest, other guys have fitted it with non M cars
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
2.5 2005 model
- gib6933
i have a cunning plan
watch this space!
jez
watch this space!
jez
X6 40d
TVR Chimaera
1916 Ford Indianapolis racer
1912 Model T
1964 Lotus 23b
1969 Lola t162
2003 Z4 2.5
TVR Chimaera
1912 Model T
1964 Lotus 23b
1969 Lola t162
2003 Z4 2.5
- pvr
Yes Blackadder ...
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
