How to reset Oil Change and Inspection counter
E85
 Ontario, Canada
I've seen BMW do it, but of course, they won't tell me the button sequence to do this when they do the oil change and service for me. I know they just use the 2 buttons in front of the steering wheel, but does anyone know how to do this?
1. Ignition in the off position.
2. Push and hold the trip reset button while turning the key to position "1" or Accessory.
3. Continue pushing the button for 5 additional seconds until the display changes and "inspection" or "oil service" appears.
4. Push the button again for approx 5 seconds until " Reset " or "RE" appears in the display and is flashing.
5. When the display starts to flash press the button a third time to actually reset that item. The new or updated service should appear and you can now shut the key off.
hi tried this and i cant get it to work it gets to the reset screen reset flashes then when i press it again it says end and stays the same what am i doing wrong ive got an early 2005 2.2 any ideas oe help would be appreciated
thanks
andy
Go to BMW and book your car in for a Oil Change or Inspection, and they will reset it for you....... at the right time.
you forgot......
6. rub your tummy & pat your head, whilst hopping on one foot.
Why?
Once your cars out of warranty ( or not ) and you've finally lost all faith in the stealers ability to do anything right and you've realised that £100 per hour plus tax is perhaps a bit of a ripoff there's no harm in doing your own servicing. Most people on this forum take great pride in their cars and will without a doubt take the time to do an excellent job of servicing them. The stealer on the other hand couldn't give a t*ss about your car. I would never allow any of my cars to go for 15k miles between services, anything on a car can break or wear out at any time so having it checked every 15k miles ie "the right time" to me is crazy.
Just my opinion!
or u get another mechanic to do it but they dont know how to reset. in my case, i will ignore this as i tend to reset it and not service the car. stealer plz take my money so i learn to service my car
Is there a way to change how long it is between Oil services notifications? Also isn't there an inspection time that's separate from the oil service? If so how to reset that function?
I carry out an extra oil change about half way through the onboard mileage and leave the clock, and then the garage I use for the filter and oil service sorts out the clock at that time. so the car gets an extra oil change.
I've started doing quite a few oil services for East Anglian members, meaning I can bulk buy and get prices down a bit. Unless specifically asked not to, I reset the oil service indicator which defaults to 15,550 miles. I then suggest to people that when the mileage remaining gets to 10k, that's a decent time to change the oil again (or two years if that comes sooner)
