It all started with a sidelight stopping working a week ago and at the same time my headlight (on the same side) started flickering. The headlight died shortly afterwards. Now the computer has switched my main beam to be used as the headlight and the indicator is permenantly on in place of the sidelight (not flashing).
I took the hatch off to check the bulbs and they are fine. (apart from the sidelight which i havent checked yet). There is a huge puddle of water and sludge (leftover from a failed attempt to cure my condensation problems with a bag of silica crystals) coating the wires.
Any ideas what i can do? I am going to take the headlight off and dry it out at the weekend. Other than the water causing a short-circuit i cant think what the problem could be, considering the bulbs are ok.
Car is an 04 with halogens. The opposide side of the car is fine.
