I finally got around to removing the clutch delay valve (CDV) and replacing it with a modified one (http://www.zeckhausen.com/CDV.htm) . Upon first ride, I was surprised as I thought there would be a night and day difference. But now that I've been driving it for a few days, that difference is VERY obvious. I think this is the reason why....
My Z4 is my first manual transmission car so I was very adept at driving with the standard CDV. So I thought the modified one would let me drive the car completely differently (ie, sloppy) without the "jerkiness." As it turns out, the modified CDV doesn't let me actuate the clutch any differently. HOWEVER, it does change the way the car behaves when I use the clutch normally. So my actions aren't any different, but the behavior of the car is VERY different! The shifts are MUCH smoother....just what I was looking for. However, the biggest difference is one that I don't hear mentioned very often. That difference is how much faster you can get on the gas after a shift. Pulling away from a stop or shifting under hard acceleration really let's you get off the clutch sooner and on the gas WAY faster...and I'm pretty sure that equals faster acceleration!
Now on to the next mod...an ESS TS2 Superchager!!!! I'm doing dynos before and after and will post both. Thanks to the guys at Goodspeed (http://www.goodspeedperformance.com/ Scottsdale, AZ ) for taking on this project! More to come in another post.
