shabba said:Yes for those type of badges I would usually use a hair dryer and/or a sponge with really hot water. Then use dental flose to ease it off, have some t-cut ready just incase too.
Ian_Mac said:I'm hoping the tin of adhesive label remover from work will do the trick - o
Nitromors works wellBreaker said:Ian_Mac said:I'm hoping the tin of adhesive label remover from work will do the trick - o
When I took the Z4 badge off the rear of mine I used some of that. Worked well.![]()
RichardG said:Perhaps I should have been more specific, I replacing all the BMW Roundells, not removing a Z4 or Engine size Badges.
Apologies for any confusion.
cj10jeeper said:Boot lid is a real tight friction fit on 2 pins into the boot. Lever it out but worry about your paint...lol
