SMG upgrade to CSL spec
- kis
This is to take all the slightly irrelevant chatter away from the hardtop thread I created
So all info regarding the upgrade can be discussed here
To paint the picture Marius mentioned some sort of gearbox upgrade within the e85 to CSL SMG spec. I'm sure this was via a software or programming upgrade as opposed to physical gearbox swap / upgrade.
If anyone has already done it, please detail
Thanks, Kis.
Thanks, Kis.
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- mac27040
as far as i'm aware the CSL was in the M3 which is a different gearbox, our gearbox is SSG the first generation thus not compatible but happy if there is an upgrade as i would be interested in it.
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
- mac27040
Considering its just a file, yo can upload Csl one and see if it works, if not just go back to old software. Takes around 30min to load it so better have external power source.
- mac27040
The problem is we are not running SMG2 so wont be compatible, also high risk of wrecking module.
- GuidoK
The z4 SMG ecu is from a different manufacturer than the M3 smg ecu (MM vs Getrag).
My guess is that you either get a checksum error, or that you brick your ecu.
Dealer price for the ecu is over 800quid so it aint cheap.
And remember, if you brick your SMG ecu, you probably cant move or drive your car, so even getting it to moved to a dealer to fix it might even be a costly affair.
I'll compare smg1 and smg2 software when im bored
- GuidoK
SMG 1 and SMG2 are e36m3 and e46m3
Z4/e46 non m3 SMG is I believe officially/technically called SSG.
If the file sizes are the same it might be flashable. Different manufacturers might use same processor technology of course.
- mac27040
for starters smg2 has launch control, smg1 (ours) doesn't
- Rusky
Guys does your gearbox rev match on down shift, noticeable from 3rd to 2nd, i believe that this indicates that its running the updated software. I thought that the same SSG was fitted into the 3 series CSL and as stated the SMG was in the M3s
3.0l Silver SMG, whippy and ginge fringe/ Sound gen mod/ Media bridge fitted (bluetooth and audio streaming) / Clear third break light/ Hard Top/ Eibachs springs and DLV back box/ Roof motor in the boot/ plus lots more.
- Rusky
Just been hunting around the internet and found this thread
http://forums.m3cutters.co.uk/showthread.php?t=109018
Mine does this and the only lurching i get is when its in sport and quickly on and off the throttle. (Learning curve and i dont use sport in traffic anymore)
Has anyone got an smg that doesn't rev match?
Hi all! I have 2004 3.0i Z4 SMG, I do not know does this "upgrade" help my shifting issue, SMG work just fine, but there is one huge comfort issue while shifting. When upshfting the car lift throttle too early compare shifting timing, so you "hit" your head to steering wheel when the shifting start...SMG shift... and when the clutch sticks it always "klunk" the driveshaft/rear. It realy feel like you have a bad driver who cant shift smoothly, insteady always shift poorly shaking co-driver back and forward/ "klunking" the powertrain as well...
When I manualy drive example with 2-gear and "pump" the gas pedal like crazy, the powertrain is smooth without any "klonk" noises. So there is no bad rearend/gear or bad driveshaft. The SMG robot just cant change smoothly.
I have changed
- New Transmission oils
- SMG hydralic oils
- SMG has been reset on lockal BMW dealer
And it is still as poor as it was before those maintances...
It feels that it would be much better if it not lift the gas totally, example with 50% gas lift it would be much smoother??
I have changed
- SMG hydralic oils
- patriot66
Oh here we go again ! SMG is NOT clunky. I welcome anybody to come out with me and either driven hard or soft mine is smooth as silk
- kis
Sounds like a bad clutch IMO? You've replaced most of the oils? Seems like the gear isn't engaging properly or smoothly? Possibly some sort of sensor but beyond my knowledge or expertise!Tomcat wrote: ↑Tue Jun 19, 2018 11:10 am Hi all! I have 2004 3.0i Z4 SMG, I do not know does this "upgrade" help my shifting issue, SMG work just fine, but there is one huge comfort issue while shifting. When upshfting the car lift throttle too early compare shifting timing, so you "hit" your head to steering wheel when the shifting start...SMG shift... and when the clutch sticks it always "klunk" the driveshaft/rear. It realy feel like you have a bad driver who cant shift smoothly, insteady always shift poorly shaking co-driver back and forward/ "klunking" the powertrain as well...
I have changed
- SMG hydralic oils
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
